OMG more oil change nightmares..(i think) - Ford Powerstroke Diesel Forum
post #1 of 16 Old 05-29-2010, 07:18 PM Thread Starter
well i got to looking at my oil change paper again and it says 5w-20.. ive been reading on here about 10w-30 and (5-10w)-(40-45)weight oil. is this a bad vis oil??
Rwill is offline
post #2 of 16 Old 05-29-2010, 07:30 PM
powerhoghp's Avatar
5w20 is recommended for small gasser motors. The 6.0 can run a 5W, but its better suited for winter. 10w30 and 10w40 are better for warmer months. I believe the manual recommends 10w40.
powerhoghp is offline
post #3 of 16 Old 05-29-2010, 07:30 PM
mustangman02232's Avatar
Send a message via AIM to mustangman02232 Send a message via Yahoo to mustangman02232
where did you get it done? 520 is rec for a gasser?
2009 F350 CCSB Lariat 5.4
fisher MM2, 20% tint, leveled
2003 mustang cobra vert
SLP LM1, CAI, diablow tuner
2004 F350 reg cab 4x4 6.0 (SOLD)
exhaust/tune/deleted, dieselsite coolant filter, CAT ELC, blue spring, fisher MM2,
13.9 @95 mph
2002 Mustang 3.8 auto vert boltons (SOLD)
90 F350 RCLB IDI (SOLD)
mustangman02232 is offline
post #4 of 16 Old 05-29-2010, 07:32 PM
powerhoghp's Avatar
The duratec's in the fusions,etc run 5w20 I believe the mustangs and gas pickups still recommend 5w30....
post #5 of 16 Old 05-29-2010, 08:14 PM
Is it the right spec. API CJ-4
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS Expandable Pyro
AutoMeter Fuel Pressure Gauge
Updated Fuel Reg. Kit 3C3Z-9T517-AG
Amsoil By-Pass(Amsoil 5w40)
Delo ELC Coolant
Coolant Filtration System
pulling a 14,000 lb Alpenlite 5er
97 F350 4x4 PSD CC LB
PacBrake&ATS converter lockup
3" dp 4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A piller EGT,Boost,Trans
2 stroker is offline
post #6 of 16 Old 05-29-2010, 08:16 PM
powerhoghp's Avatar
I didnt think 5w20 could meet the API specs..?
post #7 of 16 Old 05-29-2010, 09:55 PM
amdriven2liv's Avatar
Quoted: 4 Post(s)
I had mine changed, and the little tag in the window says 5w-20. I cornered the guy about it and he said it was the only way they could code it as being a "diesel" oil change. they did put in the right rated oil, it just freaks me out each time I see it.
2004 F350 6.0L CC LB 4x4 King Ranch
amdriven2liv is offline
post #8 of 16 Old 05-30-2010, 04:43 AM
nightstalker's Avatar
I just check the amsoil look up guide for your year vehicle, this is what we offer for that vehicle, not tryin to sell you anything, just showing the range of options and the the temps there reccomended for Engine Oil
Grade 1......CI-4+
SAE 15W-40 Synthetic Heavy Duty Diesel and Marine Motor Oil (AMEQT)
SAE 15W-40 Synthetic Blend Diesel Oil (PCOQT)
Synthetic 5W-40 Premium Diesel Oil (DEOQT)
Series 3000 SAE 5W-30 Synthetic Heavy Duty Diesel Oil (HDDQT)
-9 To 90F......10W-30 [1]
-20 To 30F......5W-30, 5W-40 [2]
-20 To 0F......0W-30 [2]
above 10F......15W-40 [3]
Manual Transmission,S6-650 W/ COOL......MA
nightstalker is offline
post #9 of 16 Old 05-30-2010, 04:53 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
5W20 is not a diesel rated oil.
However running 5w30 or 10w30 in the summer isnt gonna make a damn bit of difference. They both lubricate exactly the same.
the 5w and 10w difference is how they react in colder weather
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #10 of 16 Old 05-30-2010, 05:43 AM
Quoted: 6 Post(s)
According to Ford, the 5W40 is good for -20*F to over 100*F.
Mark
06 F250CC SB FX4 Lariat;ARP studs;OEM gaskets; Banks exhaust;DynaTrac Ball joints;Coolant filter; High-Idle;RACCCV6000;JimmiJammers;Ravelco;SynchroMax trans case;Fumoto valves;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower270AXP;PowerInverter;Rancho7000's; BPD EGR cooler;One-piece HPOP fitting;BilletWaterPump;SCT w/ Matts SRL;ELC Ultra
bismic is offline
