Blackstone Report High Copper - Ford Powerstroke Diesel Forum
Old 05-28-2010, 10:05 PM
Got my 1st O/A today. It don't look good.
From Blackstone
The high copper and lead readings would initially suggest a serious problem developing in the bearings, but these levels of metal also tend to turn up when Restore additive has been used. If that is not the case here then this 6.0L may need some attention. All other wear metals read right around universal averages, which are based on an oil run of about 5,200 miles. The oil's viscosity was quite low for 5W/40, reading more in the 10W/30 range. No fuel was present, and the TBN read strong at 7.3, showing lots of active additive left. Let us know on the Restore.
No Restore has been added, Only 24,000 miles. Rotella 5-40W synthetic 2,600 miles.
I have warranty until 6-18-10 Any Ideas?
Old 05-29-2010, 05:38 PM
Could be turbo CHRA wear. My Copper was high and then turbo went.
Old 05-29-2010, 09:20 PM
I just checked some of my reports, i have Halton do mine, and the Copper on my 97 over the past 13 year's have ran between 1 & 3 and i have only had one sample on my 06 and it came back 5 you must have something in there coming apart.
2 stroker
Old 05-30-2010, 05:41 AM
After adding Rev-X the Turbo did spool up quicker and Had more PSI. I Will go by Dealership to see if the can check the Turbo. Then it will probably take 2 weeks and I'll be out of warranty.
Maybe I should do two Cheap oil changes If they replace Turbo to clean out oil system.
Anyone know if that high of copper will cause damage to the HPOP and Injectors??
Old 05-30-2010, 06:09 PM
I changed the coolant flter on my '07 today after about 5K miles, and noticed some copper-colored flecks and even small shavings in what I poured out of the filter. Not magnetic, and don't recall seeing them before.
Old 05-30-2010, 06:35 PM
addicted to diesel
i got high levels like that on my 7.3, i ended up deciding to rebiuld my bottom end and i had crank and rod bearings that were severly worn i got pics of how they looked. figure id put in my 2cents.
