6.0 ICP sensor - Page 2 - Ford Powerstroke Diesel Forum
post #11 of 20 Old 08-26-2010, 06:12 AM
icp
I have a 2005 f250 that threw out a 2285 code so I replaced the icp but the truck runs no differently. It still dies and runs rough and doesn't throw any other codes please help any advice will be greatly appreciated.
2005 Ford F-250
Lariat FX4 Crew Cab Short Box
70k
Stock
4" Turbo back exhaust
clueless10 is offline
post #12 of 20 Old 08-26-2010, 06:43 AM
Slacker
Evil Eye's Avatar
Quoted: 208 Post(s)
Feedback Score: 4 reviews
You need to get it scanned with a diagnostic scanner to determine what you ICP and IPR are when it is running rough.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #13 of 20 Old 08-26-2010, 02:20 PM
Firefighter Member
Shockley6.0's Avatar
ICP on the early 03' I know forsure is behind the turbo near the firewall. Need to take the ECU out and alot of other computer stuff if you do it from the top. Takes time but gives you a chance to learn your engine.
Shockley6.0 is offline
post #14 of 20 Old 08-26-2010, 02:25 PM
npccpartsman's Avatar
Quoted: 5 Post(s)
Did you replace the connector also? The code indicates either a defective sensor, which you replaced or a short to ground in the wire. Your STC fitting at the HPOP could also be going out, which is common on the 05 trucks.
I Bleed Razorback Red
Ford Makes It, International Shakes It, Casserly Fuels It, KC Turbo Spools It, SCT Tunes It, and Trucks Unlimited keeps her Rockin the Road
npccpartsman is offline
post #15 of 20 Old 08-26-2010, 02:48 PM
I've just bought a 2004 F250 Fx Ive nto made the first payment yet and ive had to work on this truck constantly. The problem now is truck starts fine idles fine yet you put it in drive it runs like junk you wait until it warms up no PROBLEMS anything !!!!! Any ideas out there.
Perry Echols is offline
post #16 of 20 Old 08-26-2010, 03:08 PM
Slacker
Evil Eye's Avatar
Quoted: 208 Post(s)
Sounds like injector stiction. Get some Rev-X or try switching to Rotella T5 10W-30.
Shawn Carlson
Proud Navy Vet
Engine Mods:
Fluidampr
4" MBRP Exhaust
MTW Stage 1 Turbo
Exterior Mods:
Evil Eye is offline
post #17 of 20 Old 08-26-2010, 05:10 PM
Thanks...... So you don't think that is injector modular or anything major turbo, stuck injector !!!! I bought 1st part of this month already replaced front wheel bearings and seals. The truck only has 123000 miles on it
post #18 of 20 Old 09-22-2010, 02:31 PM
did you ever figure out how to replace your ICP?
baer's03 is offline
post #19 of 20 Old 09-22-2010, 03:46 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
The '03 and early '04's the ICP is behind the turbo. If you crawl under your truck on the driver side and look up behind the turbo you will see the ICP and connector. You will need an 1 1/16 box wrench to cut in half ( about 5" long). It's also recommended to change out the pig tail wire harness while your at it.
The late '04-up is on the valve cover.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #20 of 20 Old 09-22-2010, 04:19 PM
NUC Motorsports's Avatar
Early build 6.0's have the ICP mounted vertically on the rear of the engine block directly below the turbo.
You'll have to remove the heat shield that covers/protects the ICP sensor from the heat that's radiated from the turbo to get a visual on the sensor itself. This heat is the main reason the ICP fails. The plastic insulation on the sensor or sensor harness melts, allowing oil to seep out of the unit which causes a grounding issue or the harness shorts out.
There are 3 bolts that hold the heat shield itself on, none of which are real easy to get to.
Once that's out of the way, it's just a matter of unplugging the wire harness from the sensor itself and removing the sensor from the block. The sensor will accept a 1 1/16 deep socket or you can pick up the specialized wrench that fits from Snap-on, Proto, Mac......etc. Opening the hood on the truck outside on a sunny day helps a bit to illuminate the area.
Most often, you'll need to replace the oil soaked and/or melted wire harness along with the ICP sensor. Ford has a replacement kit that includes the new harness plug pigtail and a fabric heat sock to slide the sensor wires through to help prevent future failures.
NUC Motorsports is offline
