ABS Light 2006 F350 - Ford Powerstroke Diesel Forum
post #1 of 12 Old 05-24-2010, 01:09 PM Thread Starter
Galaxie's Avatar
ABS Light 2006 F350
My ABS light just started to come on now and then. Any ideas on where I should start? I dont see any codes via my SCT3.
Fluid is good, I dont see any signs of somthing wrong.
Colin
59-68Galaxies, Fairlanes
54 Ford Skyliner Glass Top
60 Country Sedan Wagon
87/93 5.0s 347
Buy/Sell/Trade/Service 40s50s60s cars!
06 F350 Dark Stone XLT FX4
SCTX3 Custom Tunes
ARP Head Studs
EGR Cooler gone
MBRP Stright Pipe
Edge Insight
20" Harleys 35" AT2
2011 Tailgate
Eaton TrueTrac
2" Leveling
Black Windows/lights
Blue Spring
03 Turbo
Galaxie is offline
post #2 of 12 Old 05-24-2010, 03:42 PM
My ABS light comes on when i turn all the way to the left. Has happened ever since I had the ball joints replaced.
Had your ball joints replced recently?
niftytwofifty is offline
post #3 of 12 Old 05-24-2010, 05:05 PM Thread Starter
Galaxie's Avatar
Nope! This came out of the blue. Its sometimes on and sometimes not. The only change was new tires about 500 miles ago.
Also, can I read ABS codes with my SCT? Nothing is stored.
Colin
87/93 5.0s 347
SCTX3 Custom Tunes
ARP Head Studs
EGR Cooler gone
MBRP Stright Pipe
Edge Insight
20" Harleys 35" AT2
2011 Tailgate
Eaton TrueTrac
2" Leveling
Blue Spring
03 Turbo
Galaxie is offline
post #4 of 12 Old 05-24-2010, 09:45 PM
Drivin the 6.mOney pit
armyguy209's Avatar
Feedback Score: 6 reviews
Mine did the same thing...SCT will not read ABS codes. You need an ABS code reader for that. I replaced the sensor on the rear differential (about a 10 min or less fix) and problem solved. The dealership I bought the sensor from said they are known to go out once in a while.
Dan's baby
2006 F250 CCSB Lariat 4x4 with 2007 CR 5.9 Cummins/built Allison swap and other goodies-sold
2015 F350 CCSB 4x4 Lariat Ultimate in Black tuxedo metallic
US ARMY VET
Operation Iraqi Freedom III (1 YR served in the good ol' sandbox)
armyguy209 is offline
post #5 of 12 Old 05-25-2010, 06:41 AM
skid326's Avatar
I just had a ball joint done last week and the ABS sensor wire got cut during the install. The mechanic I talked to before I had time to take it back in said it could be a bad connection. If it isn't that it is probably the sensor.
2008 F250 KR CCSB 4x4
SCT Livewire
Banks Ram Air Intake
Flo-Pro 4" downpipe back
skid326 is offline
post #6 of 12 Old 05-25-2010, 04:51 PM Thread Starter
Galaxie's Avatar
Is there only one sensor?
Thanks guys!
Colin
87/93 5.0s 347
SCTX3 Custom Tunes
ARP Head Studs
EGR Cooler gone
MBRP Stright Pipe
Edge Insight
20" Harleys 35" AT2
2011 Tailgate
Eaton TrueTrac
2" Leveling
Blue Spring
03 Turbo
Galaxie is offline
post #7 of 12 Old 05-25-2010, 05:25 PM Thread Starter
Galaxie's Avatar
One more post and then I am going to quit worring about a stupid ABS light.... Would you start by having someone read the ABS code or do you think it is safe to say that it is the rear ABS speed sensor? Also, I am finding these things for like $15-20.
Thanks! Time for a beer and some sleep.
Colin
87/93 5.0s 347
SCTX3 Custom Tunes
ARP Head Studs
EGR Cooler gone
MBRP Stright Pipe
Edge Insight
20" Harleys 35" AT2
2011 Tailgate
Eaton TrueTrac
2" Leveling
Blue Spring
03 Turbo
Galaxie is offline
post #8 of 12 Old 05-25-2010, 06:23 PM
OregonStroker's Avatar
My abs light just came on too. As far as I know if your speedo is working your abs speed sensor on the rear diff is good. But I dont know if that is true or not. Im stumped as well. It takes a specific code reader to communicate with the abs system. Oreily didnt have it and les schwabs wanted 90 bucks an hour for diagnosis.
Built engine, rods, pushrods, cam, springs. Meth, turbo, injectors, fuel system, oil system. 3 disk billet, billet shafts built trans, 6.0 IC, exhaust, intake. Latter bars, gears, system, tint, HIDs. You know the typical stuff to make a 7.3 get out of its own way...
dont brake.
OregonStroker is offline
post #9 of 12 Old 05-26-2010, 01:24 AM
armyguy209's Avatar
Well I had mine read for free at PEP BOYS. Then I bought my part from ford for 50 bucks. Worked like a champ and no lights on the dash now.
#oregonstroker
What you heard is not true. My speedometer was working just fine. I just had the ABS light on on my dash. Galaxie...These are way more common to go out according to the dealership I bought mine from more so than the ones at the wheels.
Dan's baby
US ARMY VET
post #10 of 12 Old 05-26-2010, 04:46 AM Thread Starter
Galaxie's Avatar
#oregonstroker
Armyguy #1 thank you for your service. #2 I am always nervous having pepboys scan anything. Think I should put the stock tune on before I have them touch it?
Colin
87/93 5.0s 347
SCTX3 Custom Tunes
ARP Head Studs
EGR Cooler gone
MBRP Stright Pipe
Edge Insight
20" Harleys 35" AT2
2011 Tailgate
Eaton TrueTrac
2" Leveling
Blue Spring
03 Turbo
Galaxie is offline
