MAX HP - Ford Powerstroke Diesel Forum
post #1 of 7 Old 05-16-2010, 12:14 PM Thread Starter
cam406406's Avatar
MAX HP
i am wondering what the max power i can get out of a 6.0 is with just a stud kit exhaust an tunes what will the stock turbo do will it make more than 29 lbs will the injectors keep up i am looking for like 475 hp or more or les is this possible and who can make me a good tune to do this???
cam406406 is offline
post #2 of 7 Old 05-16-2010, 12:26 PM
Goose350's Avatar
The best you can do without doing injectors is ~450. This would be with custom, custom FICM programming and a fuel system.
The Mullet Mod
Stock 2005 F-350 4x4
*Afe Intake
*4" TB Exhaust
*Scangauge
*SCT
oil bypass
water pump
*Tuned FICM
Goose350 is offline
post #3 of 7 Old 05-16-2010, 12:36 PM Thread Starter
cam406406's Avatar
really thought u could do more
post #4 of 7 Old 05-16-2010, 12:56 PM
back in the saddle
shu873's Avatar
stock injectors are the biggest limiting factor. Low to mid 400 RWHP max on stock injectors. If you want any more than that out of a 6.0 it will cost you....
Kurt
'06 True Blue/Silver 250 crew cab
ARP's, EGR blocked
AFE stg.2, MBRP 4" pipe
Air Dog 150, ITP reg. return
Bulletproof oil bypass system
Banks technicooler
Ride rite air springs in the rear
EGT, boost, and fuel pressure gauges by DiProcol on the pillar
Plus a few other odds and ends...
shu873 is offline
post #5 of 7 Old 05-16-2010, 01:04 PM Thread Starter
cam406406's Avatar
so the stock turbo is good for more but the injectors suck what can i get hp wise with just injectors and a stock turbo could i get 500hp with just inj swap and tune?
post #6 of 7 Old 05-16-2010, 01:11 PM
back in the saddle
shu873's Avatar
What supporting mods do you have done so far? If you want your truck to be reliable it will take a lot more than just throwing a 1500-2000 set of injectors in it.
Injectors alone with really good custom tuning will get you north of 450. I don't like throwing a hard number out there because if you dyno it they're all going to be a little bit different. The only way I know to prove HP without a doubt is at the track.
Kurt
ARP's, EGR blocked
Banks technicooler
shu873 is offline
post #7 of 7 Old 05-16-2010, 03:43 PM
Lt. Negativity
RescueF250's Avatar
Actually you can produce some decent numbers on a stock set-up but your pushing the limits. Matt at Gearhead did 490hp I believe on a basic stock truck, with egr delete, intake, exhaust, ficm and 6 speed. But that is maxing out the motor so not sure how long it would last and thats custom tuning.
You can upgrade your injectors with a stock turbo but then your maxing the stocker with that much fuel, so your not getting the right amount of air. You wont get the best numbers caues of the set-up. Like said already everything has a supporting mod to it it goes hand in hand.
Matt at Gearhead,Doug at GoGo,Dave at Diesel Innovations,Ryan at Full Force Diesel,Eric at Innovative. Adam at First Coast
Built 2003 with 04.5-07 parts,Hey its a hybrid
Totaled
New Era Rescue 08 F250 CC/SB No limit stuff, H&S stuff, Fl pro stuff.
RescueF250 is offline
