2005 Fuel Capacity - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-01-2010, 04:42 PM Thread Starter
fiffer's Avatar
2005 Fuel Capacity
how can I tell how big my fuel tank is or do any of you know how big the tank is on a 2005 Ford F250 Crew Cab Short Bed 6.0l. thanks in advance
Christopher Cerrone
-2005 F250 Lariat 6.0l CC, SB, ARP Headstuds, EGR Delete, Turboback MBRP SS 4" Offroad Exhaust, AFE Stage 2, Rancho Shocks, Rancho Dual Steering Stabilizer, Mag-Hytec Diff Covers, Mag-Hytec Trans Pan, Issopro Gauges, 20" Black Rockstars w/ 35" Nitto Trail Grapplers, 2.5" Ready Lift Leveling kit, Bushwacker "Pocket Style" Flares, N-Fab 6-step Nerf Bars, Edge Insight CTS Monitor, SCT X3 w/ Innovative tunes, Recon Tails, Recon Third Brake Light, Recon Mirror Lenses.
fiffer is offline
post #2 of 7 Old 04-01-2010, 05:08 PM
29 gallons is the max but i never really ever get but 26 in my 05 unless you wanna be at the pump all day
corey.beggs is offline
post #3 of 7 Old 04-01-2010, 05:58 PM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
The paperwork says 29 gallons but it will hold over 31 gallons.
If you want to make it easy to use the full capacity then read this thread about the Harpoon mod: harpoon mod ?
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Bulletproof EGR cooler, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
post #4 of 7 Old 04-01-2010, 07:10 PM
Davey~do's Avatar
David
2016 CCSB SRW FX4
Davey~do is offline
post #5 of 7 Old 04-02-2010, 02:37 PM Thread Starter
fiffer's Avatar
thanks for the replies, id assume the book is right at 30.5 where are you getting the 29gal? Ive heard 29 alot before on here
Christopher Cerrone
fiffer is offline
post #6 of 7 Old 04-02-2010, 03:38 PM
Quoted: 23 Post(s)
The 03's and 04's (short box) were 29 gallons.
The 05's and up were 30.5.
Mark
06 F250CC SB FX4 Lariat;ARP studs;OEM gaskets; Banks exhaust;DynaTrac Ball joints;Coolant filter; High-Idle;RACCCV6000;JimmiJammers;Ravelco;SynchroMax trans case;Fumoto valves;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower270AXP;PowerInverter;Rancho7000's; BPD EGR cooler;One-piece HPOP fitting;BilletWaterPump;SCT w/ Matts SRL;ELC Ultra
bismic is offline
post #7 of 7 Old 09-28-2016, 08:32 AM
You are incorrect. The tank holds 30 gallons. Here is a direct quote from the service manual. "F-250/350 SuperCab and Club Cab with 361 cm (142 in) or with 396 cm (156 in) wheel base 115.5 liters (30.5 gallons) "
jmsmith is offline
