cat delete?? - Ford Powerstroke Diesel Forum
post #1 of 23 Old 03-28-2010, 05:50 PM Thread Starter
cat delete??
i have a 4 inch cat back mbrp nothing special i work with the truck its not for show i dont have anything done to it thats it. i want it louder but not really loud. how much louder would it be to do a cat delete and could it mess anything up not woried about cops giving a ticket cuz here they dont care. what u think is it worth doing it. any more performance? alot louder? mess anything up?
warren2312 is offline
post #2 of 23 Old 03-28-2010, 05:58 PM
Gforce33's Avatar
It is actually better for your truck not to have the CAT...it is the most restrictive thing in your exhaust system. If you have the free flow MBRP muffler, with the cat deleted at will be plenty loud at WOT.
2005 F350 Kingranch FX4 Dually
6.0L Diesel,
Elite/Liberator EGR Delete.
K&N Stage II Intake.
4" MBRP Turbo Back Exhaust, Kitty Gone
2003 International Turbo.
SCT X3 SRL Tune by Matt @ Gearhead and ID's tow and street via Adam.
3 Gauge pillar W/pyro, trans and Boost
Gforce33 is offline
post #3 of 23 Old 03-28-2010, 06:03 PM
cat delete
It all depends on what year your truck is and its not going to be a whole lot louder just going to hear the turbo whistle more when it come to cats i always say someone lots smarter than me designed the truck to run with that in there for optimal fuel economy unless you have it chipped and piped with turbo upgrades its not even worth it to take it out in my opinion
nelosnst10 is offline
post #4 of 23 Old 03-28-2010, 06:07 PM
Pathfinder22's Avatar
Quoted: 2 Post(s)
Garage
Not sure I understand this one???
Thought the Cat Converter was for emissions-only and nothing to do with optimal fuel economy and in fact it adversely impacts mpg???
'06 F350 Lariat CC DRW 6.0L PSD
fully Bullet-Proof'd incl Sinister Diesel Coolant Filtration System, Train Horn, Killer Audio w/ back-up cam & 10" sub and Re-upholstered seats w/ custom canvas covers...240k plus and running strong!!
Pathfinder22 is offline
post #5 of 23 Old 03-28-2010, 06:09 PM
Abrannan19's Avatar
Feedback Score: 5 reviews
the cat is the biggest restriction of the exhaust system, ditching it is the best thing you can do for your truck, you wont get a big sound increase, but you may see a slight EGT drop. If you want some prices on a delete pipe, I can help you out, just let me know if you have stainless or aluminized exhaust system.
Adam Brannan
First Coast Diesel Performance
Abrannan19 is offline
post #6 of 23 Old 03-28-2010, 06:15 PM
RIP Cam!
Rattlesnake18's Avatar
Quoted: 1075 Post(s)
Feedback Score: 6 reviews
I say do it!!! It does not make it a whole lot louder, but when you mash the fun pedal and run wot you will hear a real nice growl. The less restriction you can get, the better.
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
post #7 of 23 Old 03-28-2010, 06:23 PM
cat convertor
Diesel convertors can rech up to 90% efficiency and reduce diesel odor and visible soot and the proper back pressure in the exhaust helps maintain proper EGT which is going to affect fuel economy and overall motor performance 2007 and later trucks are required by law to have one with a DPF as well
post #8 of 23 Old 03-28-2010, 06:58 PM
Quoted: 2 Post(s)
Garage
ok, now I am even more confused....and maybe it's me being a newbie w/ the F250 world??
So if the Diesel Cat Conv are soooo efficient and have other benefits, then why is there so much talk & so many folks running these trucks/power stroke diesel engines where they are removing the Cat Conv and upgraded from stock to 4"+ exhaust (turbo back and/or cat back) systems???
Thanks for any input.
post #9 of 23 Old 03-28-2010, 06:58 PM
Gforce33's Avatar
Nice cut and paste. Diesels run better with less back pressure, gassers require some back pressure.
6.0L Diesel,
Gforce33 is offline
post #10 of 23 Old 03-28-2010, 07:00 PM
Gforce33's Avatar
The hippies want you to think that there is something conductive with the cat for your benefit!
6.0L Diesel,
Gforce33 is offline
