Fuel Filters and B100 use - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-24-2010, 04:29 PM Thread Starter
jerseyredneck1's Avatar
I would like to know if any one knows of or uses a manufacturer of fuel filters for the 6.0 that hold up well ? Both times that I've changed fuel filters on my '07 , the fuel filter on the top of my engine came out slightly deformed when I used B100. (Not clogged that I know of , but deformed.) I was just wondering if there was a manufacturer who used specific materials like they do in service station fuel filters that sell biodiesel ?
2007 F-350 King Ranch Dually CC LB 4x4
6.0 / Automatic
Chrome Bugshield
EGR Ventvisors
Rhino Liner
Dieselsite Coolant Filter
Amsoil BMK-11 Bypass Oil Filter Kit
Amsoil AMK-02 Pre-oiler
Amsoil 15w-40 AME Oil and Filters
ARP Head Studs
High Idle Mod
Factory Ford Remote Start
jerseyredneck1 is offline
post #2 of 5 Old 03-24-2010, 04:53 PM
JER-1's Avatar
Quoted: 17 Post(s)
Cool
I think you found the problem with after market ones already, you seen the proof.
Buy ford motorcraft get em at autozone a lot cheaper than the dealer, maybe wallymart too.
JER-1
FOR SALE $19,000
2005 F-350 DUALLY
SUPER DUTY XLT
4X4,CREW CAB 8' BED
FACTORY TOW COMAND BRAKE SYSTEM
FACTORY UPFITTER SWITCHES
EDGE EVOLOUTION 11 GAUGES BUILT IN ONE
ACCUFAB INTAKE MANIFOLD
ZOODA MOD
KITTY RAN OFF
85,600 MILES, 4.10 REAR
PREVENTIVE MAINTENENCE BELOW
SINISTER EGR DELETE
OIL COOLER REBUILD
STC FITING IN HPOP REPACED NEW UPDATED ONE
COOLANT SYSTEM FLUSH 2015
NEW CAT COOLANT 11/2015
DIESELSITES COOLANT FILTER SYSTEM
7 NEW NITTO TERRA GRAPPERS
BLUE SPRING UPGRADE
JER-1 is offline
post #3 of 5 Old 03-25-2010, 12:45 AM
Quoted: 23 Post(s)
Deformed means that there is too much pressure drop across the filter. Too much pressure drop means that you will soon be replacing injectors (unless you have a high volume and high pressure aftermarket fuel delivery system).
Mark
06 F250CC SB FX4 Lariat;ARP studs;OEM gaskets; Banks exhaust;DynaTrac Ball joints;Coolant filter; High-Idle;RACCCV6000;JimmiJammers;Ravelco;SynchroMax trans case;Fumoto valves;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower270AXP;PowerInverter;Rancho7000's; BPD EGR cooler;One-piece HPOP fitting;BilletWaterPump;SCT w/ Matts SRL;ELC Ultra
bismic is online now
post #4 of 5 Old 03-25-2010, 01:46 PM Thread Starter
All my fuel filters are Motorcraft. I bought a whole huge lot of 'em on eBay when I bought the truck. As for the fuel pressure drop (which I never noticed performance-wise), does the slightly higher viscosity of B100 as opposed to ULSD cause this ? As for fuel systems , which do you prefer for a 6.0 ?
6.0 / Automatic
Chrome Bugshield
EGR Ventvisors
Rhino Liner
ARP Head Studs
High Idle Mod
post #5 of 5 Old 03-25-2010, 06:51 PM
Quoted: 23 Post(s)
Bio is more viscous. It has less BTU's so you will need about 10% more fuel delivery with it. It is a good solvent and can free up gunk. Bio itself can have contaminants or be poorly converted and be even thicker. All these will result in more pressure drop in your fuel system. Our stock fuel systems are marginal in the fuel pressure area from the factory. I have been told that Bio and steel fuel tanks are not a good combination (if you happen to have a steel tank).
You will not really see performance issues with pressures under 45 psig, but the fuel pressure needs to be there to "cushion" the injectors. Fuel pressure below 45 psig is the #1 cause of injector failure.
The most common aftermarket fuel delivery systems are Air Dog II and FASS. Several different models to choose from depending on your horsepower requirements.
Mark
