I got a stupid ?
can you do do the harpoon mod without dropping the tank? Was thinking about just taking the bed off. can it be done?
If your taking the bed off i cant see why not
ditto I dont see why you couldnt. How much more fuel do you get to put in your tank by doing this?
You can do it if the bed is off.
None, but then you don't have to squeeze the last 5 or 6 gallons in.
i'm a powerstroke rookie.... whats the harpoon mod?
but what is it? what does it actually allow?
I was told to lift the bed, but I tried, and i had ONE bolt that I broke two torx bits trying to remove. I soaked it in rust penetrant and everything. I bolted the bad back down
From my understanding, the breather tube in the filler neck allows air to go out of the tank as the fuel fills. With the end of the breather tube longer, the air quits coming up the tube when the fuel covers the end of it. This makes putting more fuel in more time consuming because the filler neck then fills with fuel clicking off the pump nozzle. Because diesel foams, it takes a bit for the foam to subside allowing more fuel into the tank. Many people don't want to wait for this pump-the-neck-full-wait-for-the-foam-to-go-down-put-more-fuel-in process, driving away with less fuel in the tank.
By shortening the tube, it allows more fuel to flow into the tank before the end of the tube gets covered. This results in having more fuel in the tank when you drive away. That's how I figure it - Some one else may come along to confirm or correct that theory. |
