EGT Probe Best Spot? - Ford Powerstroke Diesel Forum
post #1 of 19 Old 03-24-2010, 06:29 AM Thread Starter
Switchrider900's Avatar
I'm putting a EGT probe in and the in the directions I have it says to put the probe in the manifold, but they guy I have putting it in says to put it in the down pipe off the turbo for best temps. The guy that's doing it for me used to work at a Ford Dealership as a master tech.
Which is best and what do you all recommend? Also what are normal operating temps?
Thanks.
Mods:
High Idle Mod
Reverse Back Up Camera
Aftermarket Exhaust
Edge Evolution
Big Rig lights
Zoodad Mod
EGR Delete
Bocar Push Bumper
Levelling Kit
Blue Spring Upgrade
PMM Coolant Bypass kit
Want:
New Steering Wheel
Switchrider900 is offline
post #2 of 19 Old 03-24-2010, 07:55 AM
MUDSTROKIN''s Avatar
My prob is in my manifold.... and the temps changes while you drive. normal highway driving i'd say between 700-850* and if your running it hard the highest you wanna let it hit would be 1200* but don't let it stay there long...
MUDSTROKIN' is offline
post #3 of 19 Old 03-24-2010, 07:57 AM
Slacker
Evil Eye's Avatar
Quoted: 233 Post(s)
Feedback Score: 4 reviews
Most folks install them in the manifold.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #4 of 19 Old 03-24-2010, 08:14 AM Thread Starter
Are you going to see must temp change if you put it in the down pipe past the trubo compared to the manifold? If so, I'll have to try and convince the tech to put it in the manifold!!!
Mods:
High Idle Mod
Aftermarket Exhaust
Edge Evolution
Big Rig lights
Zoodad Mod
EGR Delete
Bocar Push Bumper
Levelling Kit
Blue Spring Upgrade
Want:
New Steering Wheel
post #5 of 19 Old 03-24-2010, 08:22 AM
I'm pretty sure the best place to put it is gonna be your manifold... i don't know anything about the temp readings if you put it in the downpipe as i have never done that...
post #6 of 19 Old 03-24-2010, 08:36 AM
Slacker
Evil Eye's Avatar
Quoted: 233 Post(s)
Downpipe will be between 200 and 300* cooler.
Shawn Carlson
Proud Navy Vet
Engine Mods:
Fluidampr
4" MBRP Exhaust
MTW Stage 1 Turbo
Exterior Mods:
Evil Eye is offline
post #7 of 19 Old 03-24-2010, 08:55 AM
Lubbockguy1979's Avatar
Quoted: 8 Post(s)
Send a message via Yahoo to Lubbockguy1979
A lot less accurate in the down pipe. A lot can happen from the manifold to the down pipe. I'd put it in the manifold. Its your money I'd have it my way
Randy
2006 f250 4x4
crewcab shortbed
lariat auto
Some tuning, gauges and other assorted non factory dodads
Lubbockguy1979 is offline
post #8 of 19 Old 03-24-2010, 08:58 AM
dsljnky's Avatar
Send a message via AIM to dsljnky
In the manifold obviously only measures on side tho. when I boutght my truck it was in the dp.
02 lb7
97 7.3
dsljnky is offline
post #9 of 19 Old 03-24-2010, 09:44 AM
i have it about 2" behind the turbo... i feel better knowings its back there and i am getting a reading from all 8 cylinders and no junk can go through my turbo.
pretty sure most of the 'bigrigs' have it behind the turbo too.
cruising around i see 600 on a steady grade empty in 6th gear
if i were to do it into the manifold i would remove it first... but what do i know
jeffyg is offline
post #10 of 19 Old 03-24-2010, 10:21 AM
Quoted: 8 Post(s)
Temps post turbo are less accurate. There is less fluxuation as well. it does only measure one bank of the exhaust but as others have posted there is little difference between the 2 manifolds when they have installed dual pyros. Most tempratures given are pre turbo so if you are seeing a 1200* egt post turbo you actually 1400-1500 pre turbo. I had no issue and probably half or more users have had zero issues drilling and tapping the manifold on the truck. 99% of the debris fall due to the design of a drill bit and the fact that you are drilling up (gravity). I had no issues doing mine 20k ago I drilled in 2 steps and did not use grease. Adding grease defeats the design of the drill bit. The turbo at idle is open so if there were some debris which would be really small it would pass thru the turbo with out a issue. Just because big rigs do something one way does not mean it works well for a 3/4ton or 1ton truck. Our trucks have a lot of smaller items. The service demands are also a lot different. It is apples to oranges. I'd want my gauge to be as accurate as possible. So pre turbo you will know for a fact. After turbo you can only guess if it is 100-300* off.
Randy
2006 f250 4x4
crewcab shortbed
lariat auto
