Preventative Maintenance? or waste of money? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-23-2010, 04:22 PM Thread Starter
deviusdragger's Avatar
Alright guys well within the coming weeks im gonna be doing some engine work to my rig. So far i have the fan clutch and am eyeing the coolant filter kit and am blocking off the egr.. My main problem is wether I should buy an oil cooler since im gonna be doing some engine work. I dont think anything is wrong with it, atleast while at normal operating range my temp differences are within 15 degrees. Only time i see a big difference is in the morning when i first get her rolling. It can get up to a difference of 25 degrees. So my question is....is my oil cooler going out? if not, should i just buy an oil cooler and install as "preventative maintenance"? Give me some ideas guys!!! Thanks!
2003 F250 charcoal
Full 8inch ORU suspension. I mean everything. with bilsteins all around. Rear airbags.
SCT Tuned by Innovative with BANKS stickers still.
Banks Techni-cooler and full intake.
Full banks monster exhaust with gato dead.
Pro-Comp 37's on black 17's.
Amp steps, Hella of alot of Hella lights. 12 total.
AND FINALLY.....Head studs.
And a pretty lady sitting next to me While i blow black smoke...
:burnout
deviusdragger is offline
post #2 of 5 Old 03-23-2010, 07:37 PM
Slacker
Evil Eye's Avatar
Quoted: 209 Post(s)
Feedback Score: 4 reviews
When it's warming up, the temp differential will be a bit higher since the thermostat hasn't opened up. I wouldn't think you are having an oil cooler problem since it doesn't manifest itself when your engine is up to temp. Just my opinion.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #3 of 5 Old 03-23-2010, 08:22 PM
I never see the differential to be more than 11 degrees on my DashDAQ. When I am warming up, the oil temperature takes longer to heat up than the coolant temperature. Several people I know that have new oil coolers never see a differential more the 6 or 7 degrees. I would tend to go ahead and replace it, but I am VERY conservative.
Mark
06 F250CC SB FX4 Lariat;ARP studs;OEM gaskets; Banks exhaust;DynaTrac Ball joints;Coolant filter; High-Idle;RACCCV6000;JimmiJammers;Ravelco;SynchroMax trans case;Fumoto valves;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower270AXP;PowerInverter;Rancho7000's; BPD EGR cooler;One-piece HPOP fitting;BilletWaterPump;SCT w/ Matts SRL;ELC Ultra
bismic is offline
post #4 of 5 Old 03-23-2010, 08:45 PM
JER-1's Avatar
Quoted: 17 Post(s)
Cool
Put a new one in mine oil temps take alot longer to get up to temp. mostly they run about the same or within 4 degrees all the time unless I'm towing then anywhere from 8 to 15 pulling hills.
JER-1
FOR SALE $19,000
2005 F-350 DUALLY
SUPER DUTY XLT
4X4,CREW CAB 8' BED
FACTORY TOW COMAND BRAKE SYSTEM
FACTORY UPFITTER SWITCHES
EDGE EVOLOUTION 11 GAUGES BUILT IN ONE
ACCUFAB INTAKE MANIFOLD
ZOODA MOD
KITTY RAN OFF
85,600 MILES, 4.10 REAR
PREVENTIVE MAINTENENCE BELOW
SINISTER EGR DELETE
OIL COOLER REBUILD
STC FITING IN HPOP REPACED NEW UPDATED ONE
COOLANT SYSTEM FLUSH 2015
NEW CAT COOLANT 11/2015
DIESELSITES COOLANT FILTER SYSTEM
7 NEW NITTO TERRA GRAPPERS
BLUE SPRING UPGRADE
JER-1 is offline
post #5 of 5 Old 03-23-2010, 11:22 PM Thread Starter
Well I guess a new one it might be. My oil always runs a little hotter than my water. Especially once I hit a grade. But always within 15 degrees. But the warming up from being is where I see the biggest difference.
2003 F250 charcoal
:burnout
