Head gasket
I am working on a 05 F-350 with a 6.0 in it and was wondering what I need to remove to change the head gaskets? Can i pull the engine without lifting the cab off? Can i change the head gaskets without pulling the engine?
you can do hg's cab on and engine in its just easier to pull the cab to do the job. i dont know for sure what all you have to pull the but the turbo,intake, accesories, injectors, lots of electrical connectors, other than those things idk
You can change head gaskets with the cab on and without pulling the engine. The problem arises when you try to use ARP studs instead of the Ford TTY head bolts. If you are doing studs remove the cab or pull the engine.
