6.0 long crank time????? - Ford Powerstroke Diesel Forum
Old 03-22-2010, 05:19 PM
Hello all, I am new to this and new to the diesel world. My 06 6.0 is taking 5 seconds to start cold, is this a problem. its runns smooth.
Old 03-22-2010, 07:44 PM
Mine is also doing this i have taken it to the dealership and they reflashed it and put a new ficm in and it did not fix the problem. Is this normal for them to take that long to start?
Old 03-23-2010, 02:15 AM
I had the same thing and was told it is completely mormal
Old 03-23-2010, 05:49 AM
It started doing this about six months ago. It just all of a sudden takes twice as long to start
Old 03-23-2010, 05:51 AM
I had the same problem and i was told by an old diesel friend of mine to pump on it a couple time while starting on it and now no problem.
Old 03-23-2010, 09:00 AM
Thanks, I will try to pump on it once
Old 03-23-2010, 11:14 AM
And typing to meet the minimum number of characters needed to post....
Old 03-23-2010, 11:25 AM
i gotta ask how in the hell is pumping the throttle going to help it start? it fuel injected
Old 03-23-2010, 03:09 PM
well i don't know about pumping the throttle, but i'll try anything at this point.
mine is doing the exact same thing as op, been to the dealer and new flash & new ficm, same long crank.
went back and tech told me within 5 sec is ford spec, but prior to a couple months ago started immediatly, once it starts it runs flawlessly, warm starts i can't hardly get my hand off of the key fast enough.
tech checked glow plugs, harness, gpr, and everything checked ok, no codes.
any suggestions???????
Old 03-23-2010, 03:19 PM
what oil do you use?
