preventative oilcooler EGR replacment? - Ford Powerstroke Diesel Forum
Old 03-22-2010, 04:27 PM
Question preventative oilcooler EGR replacment?
instead of an EGR delete (I do want to remain legal) it was recommended to me by the mechanic to have an oilcooler replacement as preventative measure. The truck (6.0 Powerstroke 2005) has now 90000 miles and there is no sign of anything wrong with it. I was told that most failures of sticking occur around that milage. They actually even recommend to do this every 30000 miles. There has been no such replacement till now on this truck.
The cost would be around 700 for work and 500 for parts (cooler and gasket kits..) if the EGR valve would have to be replaced as well on inspection there would be additional 130 for it.
As it is quite costly, should I have it done? What is your opinion about this?
Old 03-22-2010, 06:15 PM
If it aint broke........DONT FIX IT. I would not worry about it if the truck has made it to 90k without issue dont throw the money at it.
Old 03-23-2010, 04:23 AM
Get a set of guages to monitor oil temp & coolant temp. If the oil is 15* or more hotter than your coolant temp, then its time to change it (oil cooler).
Old 03-23-2010, 02:07 PM
Thank you for the recommendation. I will get an Edge Insite monitor which plugs to the diagnostic port to monitor the 15* difference.
