CCV Ignorance please enlighten me... - Ford Powerstroke Diesel Forum
Old 03-22-2010, 03:05 PM
any drawbacks/difference between this cost saving setup like this
Questions and Comments about the CCV reroute
Did some upgrades
versus ones like this?
Ford Truck Enthusiasts Forums - MoyockPowerstroke's Album: CCV Filter
and wouldnt the 1st setup with the breather cap be more practical then to get a by-pass or non bypass filter setup and potentially causing a pressure issue should the setup be clogged?
Old 03-22-2010, 03:14 PM
Im no expert on this, but I do know if that hose gets smaller or clogged you will have oil leaks fast
Old 03-22-2010, 03:22 PM
oil leaks from what, the setup itself??
Old 03-22-2010, 06:47 PM
oil leaks from oil being pushed past the seals, like the rear main from all the crankcase pressure not being able to escape.
Old 03-22-2010, 08:19 PM
then maybe its not worth the risk.
Old 03-22-2010, 08:25 PM
just make sure the hose has a free path, i check mine periodically to make sure its all flowing good. no problems here.
Old 03-22-2010, 08:33 PM
how about i throw another one into the mix: CCV Mod
