How much coolant to drain - Ford Powerstroke Diesel Forum
Old 03-19-2010, 05:04 PM
How much coolant do I need to drain out before doing the EGR delete kit?
Thanks, Rick
Old 03-19-2010, 05:09 PM
If it aint a CAT itsa DOG
Bump this up for ya Rick as i will be doing this mod myself in the near future.
Old 03-19-2010, 05:21 PM
I'd just pull the lower rad hose...do the delete and fill with 50/50 Zerex G-05.
Old 03-19-2010, 05:30 PM
when i did mine, i just put a 5 gallon pale under the rad and pulled the drain valve.
Old 03-19-2010, 09:08 PM
You will only need to drain around 3 gallons, but it would be a good time to just change the coolant while you are there. Put Motocraft gold back in it.
