SCT - Ford Powerstroke Diesel Forum
post #1 of 3 Old 03-19-2010, 04:58 PM Thread Starter
Special K's Avatar
SCT
So I am planning to get my SCT and EGR delete done in a couple of weeks or so. Of course I want a exhaust turbo back and and leveling kit too. I was thinking of just cutting out the cat and muffler on my stock exhaust and just using it for time being. Will this work with the SCT and will I have to change settings later for a different exhaust? When getting the SCT do I have to let them know that I am doing a EGR delete?
Special K is offline
post #2 of 3 Old 03-19-2010, 05:18 PM
MoyockPowerstroke's Avatar
Nothing wrong with dumping the cat and trash can of a muffler...either way it helps lower egt's....With your 3" DP, you should be okay...but you might throw a full flow muffler on there until you decide on a solid exhaust system. There are no settings on the SCT for exhaust differences...and you do not need to let your tune writer know about deleting the EGR...most of them write tunes deleting it anyway...but you could mention it. Main thing to worry about with tuning is gauges...need to know what all the temps are....especially egt's ect and eot.
'05 6.0L, 128k miles, Racor CCV6000 Filter, Oil Bypass Filter, Fumoto drain valves, Coolant Filter, ZooDad, HighIdleMod, BullyDog 4" TB, VXCF9 Strat, Edge Insight Gauge, Torque App, Fuel Press Gauge, Upfitters, 4" SJ lift w/Bilstein 5100's, Ride-Rite Airbags, Rough Country Dual Stabilizers, 24" Wipers, '08 Rear Diff cover, Mobil1 Syn 5W-40, 6.4L banjos, Blue Fuel Spring, SS HPOP screen, '08 Mirrors, Zerex ELC.
MoyockPowerstroke is offline
post #3 of 3 Old 03-19-2010, 05:47 PM
Abrannan19's Avatar
Feedback Score: 5 reviews
good info..BUT just to be clear, its best to tell the tuner that you are going to be having a full EGR delete, while most tuner (if not all) disable the EGR valve in tuning, they do not disable CEL's that are associated with an EGR delete such as an incomplete EGR circuit, etc, etc..so its a good idea to disclose that upfront.
We can hook you up with a custom tuned SCT tuner, with tunes by Innovative Diesel, We have them in stock and ready to ship.
First Coast Diesel Performance -Product- Your Source For Powerstroke Performance
Adam Brannan
Abrannan19 is offline
