What is this? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 03-19-2010, 03:30 PM Thread Starter
What is this?
What is this thing? Its making a buzzing noise constantly and I have no idea what it is...
bvantiem is offline
post #2 of 9 Old 03-19-2010, 03:31 PM
brob1969's Avatar
vacuum pump
'06 F-250 Super Duty
6.0L Power Stroke
brob1969 is offline
post #3 of 9 Old 03-19-2010, 03:48 PM Thread Starter
Its buzzing constantly what does that mean?
bvantiem is offline
post #4 of 9 Old 03-19-2010, 03:56 PM
brob1969's Avatar
It means it's working. Is it louder than normal?
6.0L Power Stroke
brob1969 is offline
post #5 of 9 Old 03-19-2010, 03:57 PM Thread Starter
Yeah, when I turn the key for the glow plugs to heat up you can hear it buzzing and it doesnt shut off...
bvantiem is offline
post #6 of 9 Old 03-19-2010, 04:10 PM
Ryan Rønning's Avatar
Quoted: 6 Post(s)
That may be your electric fuel pump
Project Frankenstein
1997 Ford F-350, Dually conversion, Cobra 29 LX CB, 12000 watt converter, All LED lights, PHP Hydra, 4" DP, Napa Intake, coolant filter, 140cc AD Injectors and lots of running lights.
Originally Posted by XPLOSIV View Post
Thanks. I'll give er a good wackin in the morning.
Ryan Rønning is offline
post #7 of 9 Old 03-19-2010, 04:47 PM
Gene's Avatar
Quoted: 3 Post(s)
That is the vacuum pump. It is on the passenger side, right in front of the hood hinges. Mine makes a lot of noise while it is on as well. It should eventually turn off. If it doesn't, it generally means that you have a vacuum leak.
Does your heater work correctly, or does it only have defrost?
Gene
2001 F350 Crew Cab Long Bed 4x4 6 speed
PHP Hydra, 4 inch MBRP Exhaust, GTP38R, FRx, DIY Exhaust Brake, T500 HPOP, Hutch/Harpoon,
6-liter Intercooler, 6637, DIY Coolant Filter, CCV Mod
Gene is offline
post #8 of 9 Old 03-20-2010, 07:30 AM Thread Starter
Its working but its taking a while for it to change settings when you turn the dial so there must be a air leak somewhere.
bvantiem is offline
post #9 of 9 Old 03-20-2010, 09:47 AM
brob1969's Avatar
Yep, sounds like you may have a leak.
6.0L Power Stroke
brob1969 is offline
