horn and cruise control no worky
835 views 5 replies 4 participants last post by  Powerstrokingmypp
#1 ·
last friday when driving to new orleans from galveston i got up to my highway cruising speed and hit the cruise control and i got nothing i figured it was a fuse or something but i couldnt find the cruise control fuse :dunno: then today some lady mustve fallen asleep for a second at the redlight so i was going to gingerly remind her with a little toot from the horn that green means go when i pressed the horn nothing happened so i rammed her and that got her attention just kidding. checked the horn fuse it was good. my radio controls and air conditioner controls still work so anyone know if theres a fuse i need to check or have any other advice? thanks
#2 ·
Same fuse as that for your CHMSL - Center High Mounted Stop Light. Check you High center brake light...is it working? If not thr fuse to it is probably needing replaced....not sure about your horn?
#3 ·
sounds like you need a clock spring.
is your air bag light on?
#6 ·
looks like dalton was right the other day when i was driving the airbag light started blinking with no particular pattern then eventually remained steady. when i started the truck the next day it didnt come on right away but eventually did the same little blinking routine then remained steady. how hard are these clocksprings to replace?
