EGR delete pros and cons? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-16-2010, 04:25 PM Thread Starter
Question EGR delete pros and cons?
A friend of mine has an '03 F250 cc 4x4 6.0L auto, The EGR went bad and he is considering getting a delete kit for it.
Just curious if anyone on here has any input on the pros and cons? Does it effect the longevity of the engine?
The kit they looked at was from bulletproofdiesel.com $1600
A local diesel Mechanic told him that he could delete it/ bypass it for $600 and didnt need a whole kit? What he meant by that I have'nt a clue? But apparently he can do it, and a guy I spoke with had it done by him and is going on 4 months now.
Your input is greatly appreciated! Thanks - Drew
1996 F350 7.3 ZF5spd 4x4 Flatbed Dually
-4:10's
- 2" add-a-leaf
-Straight pipe w/ 6' tip
-285/75/16 Terra Grapplers
-2" dual spacers
-DIY intake w/K&N
-2 10"kicker CVR's w/audiobahn 800watt amp
Soon to come...
-3.5" dp w/ 4" exhaust
-ccv mod
-tuning....
Maybe turbo upgrade
d.austin86 is offline
post #2 of 5 Old 03-16-2010, 04:35 PM
purplehorn1977's Avatar
there is only one down side and that is if its in warrenty it will void it if you have problems. deleting it is for the better as your oil will stay cleaner the engine wil stay cleaner and the fuel milage will go up. plus your getting rid of a major problem causer. i deleted the egr and egr cooler with a homade kit got like 20 bucks in it. just have to be able to weld.
2004 F250 6.0 CC 4x4 SCT with custom tunes
zoodad mod, head studs, Home Brew EGR delete, 5" MBRP striaght exhaust, 05 headlight Conversion
HID Head and fogs.
Real courage is found, not in the willingness to risk death, but in the willingness to stand, alone if necessary, against the ignorant and disapproving herd. Jon Roland, 1976
purplehorn1977 is offline
post #3 of 5 Old 03-16-2010, 04:49 PM Thread Starter
What all exactly needs to be removed?
-4:10's
- 2" add-a-leaf
-2" dual spacers
-DIY intake w/K&N
Soon to come...
-ccv mod
-tuning....
Maybe turbo upgrade
post #4 of 5 Old 03-16-2010, 04:52 PM
willholl79's Avatar
Search FCDP, they have a great delete kit.
2005 F-350 CC LB 4x4 XL 6.0
SCT
4" Turbo back exhaust
03 turbo
Studs
Coolant Filter
Warren Stock+ injectors
1996 F-250 ECLB 4x4 XLT 7.3 Auto
1993 F350 CCLB 4x4 5spd 7.3 NA
willholl79 is offline
post #5 of 5 Old 03-16-2010, 04:56 PM
when i did mine i removed the egr cooler and cut fittings off of the egr cooler had a pipe bent and welded coolant fittings from egr cooler to tube. depending on the year there is a scoop in the up pipe that must be cut out. then cut the flanges from the egr cooler and weld them shut. bolt them to the intake and the up pipe. then i welded a plug in the intake where the egr valve went. have had it like this for over a year now and no problems.
HID Head and fogs.
