aux switch panel
i have a 2006 f350 with the 4 aux switches and 3 of them where hooked uow ehn i bought it i want to hook something up to the last one where is the hook up to do so i know there is a relay box behind the glove box and the other connections look like they go behind the fuse panel on the driverside under the steering wheel i just need a little help guys thanks
behind the fuse box. You have to take the fuse box out and then you will see the four wires
when i take the fuse panel out is there anything that can get really messed up if not carful
In my 05' I did not have to take out the fuse box.. Up behind the fuse box slightly There are 4 orange (with various stripes) wires by them selves that are for the Aux upfitter switches. Unless someone tied those wires in to the firewall pass through wires you should have one that is loose in that area and also be able to find the previous owners workings tapped in to the other 3.
Lay on your back with the top of your head up against the brake pedal. you should see them.
my 06 has them under the hood next to the hydroboost.
