common mileages when 6.0s have major failures?
is there a common mileage when 6.0s have major failures?...looking at 04 with 86k...had egr cooler, oil cooler, FICM, turbo cleaned under warranty in 07...nothing other than that...just curious...seriously looking into buying it...
No...because "most" don't have major problems....some do...most don't
Buy it.... |
i would get an oasis report on it. other than that buy it!
ok here is oasis report...
couple window switch replacements recall on reverse planet replacement remove transmission and replace reverse planet gear assy FICM wiring repair completed recall inspected FICM harness, installed shield kit, replaced ICP senson connector customer states water in fuel light stays on manifold failed replaced water in fuel manifold customer states engine overheating and blue white somke from exhaust after warmed up, can hear pitch noise from engine worse on acceleration test engine performance chart. pinpoint test.replace egr cooler. diagnostic test failed.replace hot side CAC hose.retest.failed.rnr turbo and inspect and clean. retest passed. verify 6.0 operation customer states can hear a loud high pitch whine from possible transmission engine oil cooler failed test. engine performance test. pinpoint. test. test turbo passed monitor pids. replace engine oil cooler and flush coolant. retest clear codes rd test verify60 |
They should know better than to replace the either cooler by itself! Jeez!
depending on how long ago they were replaced, thats how it used to be done... now they are replaced in pairs
How can I get an oasis report on my 06????
Call your local Ford dealer, they'll read it off to you, or you can go by and pick up a copy, or you can have them fax it to you.
very cool thankyou i didn't know you could get those...i am looking at an 07 PSD 6.0 in another state and had some questions about service history....now i know what to do thanks guys
