Does it hurt to keep changing your tune ?? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 03-12-2010, 09:58 AM Thread Starter
I have a 05 f-350 powerstroke,
i got a Superchips micro tuner,
during theweek i keep it on economy & set it to max performance on weekends,
Does it hurt the computor to keep switching like that ???
One more question, what is a flash ?
is it something i need to have done ?
i hear of guys having problems after there truck has been flashed.
thanks for all your time & help, i learn alott on this sight..
55gasser is offline
post #2 of 10 Old 03-12-2010, 10:43 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
A flash is when the dealer installs (flashes) new programming to your trucks computers. They are basically software updates to fix problems with the software/hardware on the truck.
I am pretty sure everyone here will tell you to get rid of the Superchips tuner and get an SCT with custom tunes. No it probably won't hurt the computer but I wouldn't swear on the rest of the truck.
RIP Mitch
the Org crew
PGreenSVT is offline
post #3 of 10 Old 03-12-2010, 11:57 AM Thread Starter
whats wrong with the superchips ? i only paid 150 for it & i bought it for the able to read codes. it seems to make the truck run alott better but im new at this.
55gasser is offline
post #4 of 10 Old 03-15-2010, 03:52 AM
topdwg's Avatar
Do a search, I'm sure you'll find why having a SCT is in my opinin better than having a generic based programmer. The SCT is capable of using custom tunes that you get from several different people. Once again do a search and you'll find who people like. Matt from Gearhead performance, and Eric from IDP are some of the popular ones.
2012 F-350 SRW King Ranch
SOLD - 2004 Lariat F-250 4x4
6.5 Pro Comp Lift W/ Fox Shocks, DeeZee Tool Box, 08 Diff. Cover, 37x13.5/20's Pro Comps, Zoodad Mod, SCT w/custom tunes, 4 in EX., AFE Intake, ARP, Recon Lights, High Idle Mod, RCD EGR Delete, Fumoto Valve, Oil Bypass Kit, 03 Turbo, Yukon Gears, Farmboy Stage II Traction Bars, Dieselsite Coolant Kit, Amsoil, HIDS, Edge Insight CS, PHP FICM
topdwg is offline
post #5 of 10 Old 03-15-2010, 05:55 AM
Baddestt's Avatar
Quoted: 9 Post(s)
I have the Superchips flashpaq 1855...it is a good tuner for the money ($200)...and it has a safe performance tune...but it would be more like the street tune on an SCT X3. The SCT is great if you can afford it, and its what I plan on next. But the superchips tuner has suprised a lot of Dogde and Duramax and other Fords as well...I put done 713lbs of torque @ wheels with the superchips...and it firms up the tranny shifts good...Ive had it for 30,000 miles and no issues! SCT will lay close to 800lbs @ wheels in the Xtreme race file...and it is a sick but pricey tuner
'07 F-250 PSD 4x4
5" exhaust, zoodad, blue spring, Airaid intake, 6.4 starter, 2.5 f/coils, adj Trac bar, 2" r/add-a-leafs, egr delete, snow plow fan clutch, csf 6028 intercoolerr, DC 185 alt, Bilstein 5100, Barder '03 turbo rebuild w/RR billet wheel, SCT SF3 tuner, F-Detroit Truetrac, R-Detroit Locker, 4:10 gears, hawk LTS, LT315/70r17 Duratracs, Amsoil Gear lube, Delo 400 LE 5w30 diesel, Delo ELC, archoil, bpd ficm, BPD oil cooler, dynatrac pro steer ball joints, arp studs, oem gaskets, HD water pump, stc, plugs, stand pipes, 6.4 banjo bolts,
Baddestt is offline
post #6 of 10 Old 03-15-2010, 03:40 PM
Drivin the 6.mOney pit
armyguy209's Avatar
Feedback Score: 6 reviews
The SCT with custom tunes actually tunes your transmission as well as your computer..alot of the tuners out there just tune the computer ONLY which can be hell on a transmission...
If you read the review on the forum you will probably see that pretty much everyone on here is running a SCT with tunes from either gearhead or IDP...both have good custom tunes.
With custom tunes you can tell them exactly what mods and stuff you have done to your truck and what exactly you are looking for in a tune and the tuner will make one for you....thats the good thing about them.
Dan's baby
2006 F250 CCSB Lariat 4x4 with 2007 CR 5.9 Cummins/built Allison swap and other goodies-sold
2015 F350 CCSB 4x4 Lariat Ultimate in Black tuxedo metallic
US ARMY VET
Operation Iraqi Freedom III (1 YR served in the good ol' sandbox)
armyguy209 is offline
post #7 of 10 Old 03-15-2010, 07:55 PM
smokersteve's Avatar
Quoted: 20 Post(s)
with the sct will the trany have to re-learn every time the tune is changed?
13Q Trans Fluid Flush
FICM Testing Videos
smokersteve is offline
post #8 of 10 Old 03-16-2010, 11:23 AM
Goose350's Avatar
Yep. Its not that big of a deal. I just load a tune and drive it like normal. I dont do anything special to make it "learn"
The Mullet Mod
Stock 2005 F-350 4x4
*Afe Intake
*4" TB Exhaust
*Scangauge
*SCT
oil bypass
water pump
*Tuned FICM
Goose350 is offline
post #9 of 10 Old 03-16-2010, 04:56 PM
armyguy209's Avatar
I dont know how long the actual "learn process" is but I would take it easy the first 100 miles or so just to be safe...its not going to hurt anything if you dont but just peace of mind for me.
Dan's baby
US ARMY VET
post #10 of 10 Old 03-16-2010, 07:51 PM
Quoted: 20 Post(s)
That is what im thinking. When ever I do change the flash(rare), I let it go through every gear mergin onto the highway for about 20 min (cold run and warm run) then re-start the truck before I put it through what its designed to do. This is only right after I reflash, which is not often at all.
FICM Testing Videos
