finally ordered a RCD full egr delete kit - Ford Powerstroke Diesel Forum
post #1 of 8 Old 03-09-2010, 01:32 PM Thread Starter
duke01genlee's Avatar
I finally went a head and ordered a full egr delete kit. I had a check engine light on for with the codes P0404 and P0405. I figured this would be a good time to order the kit. Me and friend of mine are going to install it. Can't wait to get it, just hope everything goes smooth.
duke01genlee is offline
post #2 of 8 Old 03-09-2010, 04:36 PM
daledozer's Avatar
Put that kit on a few weeks ago, nice kit. I had to cut the blue coolant hose almost in half to get it to fit, was a lil long, took me all day, but was the first time I ever worked on a ford. Could probably do it in half the time after doing it once, two guys will be a big help when removing and installing the up pipe. Oh, I did my exhaust that day too so I cut as much as I could with the torch saw.
04 F250 FX4 Super Cab, MBRP straight piped, RCD EGR delete, autometer z series, SCTX3, ATX Artillery wheels, 35x12.5x18 Nitto MT's.
daledozer is offline
post #3 of 8 Old 03-09-2010, 04:42 PM Thread Starter
Yeah doesn't look to bad to do just time consuming. Never worked on a diesel but I guess I'm going to learn a little about them.
post #4 of 8 Old 03-10-2010, 08:45 AM
have also just order this, they have shipped it now, hope its good.
F250 -04 CC
22" rims, 36" pirelli tires
EGR delete
Zoodad
5" lift
Autometer gauges, sportcomp,
Sct whit custom tune from matt@gearhead,,
soon ARP bolts, laying in garage..
Nyberg is offline
post #5 of 8 Old 03-10-2010, 12:00 PM
hey how did the install go?? pretty easy?? strait forward??
2005 PSD xlt fx4 6.0 (extended cab short bed)
mods:
zoodad mod
sct livewire custom tunes by TWISTED DEISEL
autometer boost, pyro and trans temp gauges
3.5" down pipe, 4" mbrp straight piped stack
AFE stage 2 intake
CFM largemouth intake manifold and intercooler pipe
12k HID's
future mods:
RCD egr delete, ARP studs & black onyx head gaskets (TWISTED DIESEL), CCV mod
chris_the_stroker is offline
post #6 of 8 Old 03-10-2010, 12:10 PM
I also had to cut my blue hose. It seemed weird, the clearance between the delete pipe and oil cooler pipe was almost zero. IMHO this really should be a bigger gap, and then the hose would have less side stress and would fit w/o cutting.
05 4x4 F-250 ExtraCab Short WB
ARP Studs
RCD EGR Delete
MBRP 4" Exhaust
Bullet Tuner
KCS250 is offline
post #7 of 8 Old 03-10-2010, 12:47 PM
daledozer's Avatar
I agree about the tight clearance. I drilled and tapped the egr valve block off plate for my boost gauge.
post #8 of 8 Old 03-10-2010, 02:36 PM Thread Starter
I hope it's good too. Can't wait to get it and somebody just told me to replace the oil cooler at the same time.
