2005 6.0 Fuel Filter Frame Rail Socket? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 02-28-2010, 11:23 AM Thread Starter
colonel angus's Avatar
Quoted: 2 Post(s)
Or Wrench or ???
Appears to be 36mm or close.
What do you guys use to get this off?
D
colonel angus is offline
post #2 of 11 Old 02-28-2010, 11:27 AM
back in the saddle
shu873's Avatar
36mm socket. Same as the oil filter housing. Also it helps to have a universal extension for the HFCM cap.
Kurt
'06 True Blue/Silver 250 crew cab
ARP's, EGR blocked
AFE stg.2, MBRP 4" pipe
Air Dog 150, ITP reg. return
Bulletproof oil bypass system
Banks technicooler
Ride rite air springs in the rear
EGT, boost, and fuel pressure gauges by DiProcol on the pillar
Plus a few other odds and ends...
shu873 is offline
post #3 of 11 Old 02-28-2010, 11:43 AM Thread Starter
Quoted: 2 Post(s)
Thanks, performed a search and will try to locate one at the Zone.
D
post #4 of 11 Old 02-28-2010, 12:05 PM
Galaxie's Avatar
Regular 36er!
Colin
59-68Galaxies, Fairlanes
54 Ford Skyliner Glass Top
60 Country Sedan Wagon
87/93 5.0s 347
Buy/Sell/Trade/Service 40s50s60s cars!
06 F350 Dark Stone XLT FX4
SCTX3 Custom Tunes
ARP Head Studs
EGR Cooler gone
MBRP Stright Pipe
Edge Insight
20" Harleys 35" AT2
2011 Tailgate
Eaton TrueTrac
2" Leveling
Black Windows/lights
Blue Spring
03 Turbo
Galaxie is offline
post #5 of 11 Old 06-25-2011, 09:23 AM
Just used this thread as my guide for the filter. Change worked great. 35 mm socket is the key. I put the socket on the filter then threaded a long extention on and i went great. Didnt drain abead of time. No need to. Just drained onto rag. Priming the pump afterwoards was also key.
Bcnarmor is offline
post #6 of 11 Old 06-25-2011, 03:29 PM
rem1981's Avatar
I have a Snap-On socket that is double sided--one side fits the oil filter cap, the other fits the fuel filter cap.
I dream of a better tomorrow, where chickens can cross the road and not be questioned about their motives.
rem1981 is offline
post #7 of 11 Old 06-27-2011, 07:09 AM
Do you have a link for this socket?
Luke Duke is offline
post #8 of 11 Old 06-27-2011, 07:36 AM
nylyon's Avatar
http://www.amazon.com/Lisle-14500-Oil-Filter-Socket/dp/B000JFL7ZS
- Karl
2003 F-250 Crew Cab Short Bed Lariat PSD 6.0 Automatic FX4 Edge Insight with EGT Probe. Coolant Filter. All 6.0's need gauges
nylyon is offline
post #9 of 11 Old 06-27-2011, 08:01 AM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
Originally Posted by nylyon View Post
Me too, picked one up at the local auto parts store.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #10 of 11 Old 06-27-2011, 08:08 AM
mks8882's Avatar
I have this one too...works great.
2007 F250 CC King Ranch, 5" MBRP Turbo Back Exhaust, SCT with SRL, Atlas 40, blue spring, dfuser coolant filter kit, EGT, Fuel Pressure, and CTS.
mks8882 is offline
