Blown Headgasket Symptoms?
like title says , What would be some common things to notice if you had a blown headgasket besides losing water in the tank? Any smells? obviously power loss, but anything way to really check? Im just used to a regular old small block ford that you can hook up a compression/leak down tester and figure it out that way. Im by no means a diesel mechanic so anything would help out thanks guys
Watch for white puffs of smoke from exhaust. Run the truck with the cap off the degas bottle and see if it is bubbling(building pressure). For the egr cooler, park the truck on a bit of a down slope and pull the egr valve and see if it is wet. If it is,that is a pretty good indication that the egr cooler is hooped. |
-Tea kettle noise or noise similar to running your finger over a wine glass on hard acceleration or decleration
-Coolant puking out the degas cap The only way to know for sure is to have it hooked up to and do a coolant pressure test and tempature test. They check the pressure at the degas bottle and identify the peak tempatures of your EOT and ECT. Based on the psi pressure identified at the degas cap, and the tempature varation between the EOT and ECT will determine if headgaskets are possibly compromized or if there are symptoms of EGR cooler failures or Oil Cooler retrictions... |
[QUOTE=ebusa;1743605]-Tea kettle noise or noise similar to running your finger over a wine glass on hard acceleration or decleration
-Coolant puking out the degas cap QUOTE] The coolant was not "puking out" but there was stains of coolant after a couple days of driving normally. I filled the tank up completely full and then i guess it settled down to the level it wanted to stay at, after a few days its now below the " Minimum" mark by a 1/4" . I guess Ill just have to bring it to a dealer and have them look at it. I dont know how to do the " EOC and ETC " tests. I got an extended warranty when i bought the truck so i guess i better use it. |
What are the chances of the dealer finding a blown head gasket, then while its apart I just happen to show up with a set of studs and ask them to install those before they button it up? Would they ask for some money for additional labor for stud install? or just flat out tell me they have to do it by the book and put head bolts back in it?
I made the mistake of having my gaskets changed about 10 months ago and kick myself now for not getting ARP's and injectors. |
It all depends on the dealer. I would definitely ask them ahead of time, dont just show up with them and expect them to do the install.
If they install them for you, definitely throw the tech some extra cash on the side |
[QUOTE=1slow6.0;1744054]
What year is your rig? do you have the recall sticker showing the newer fill line? Make sure you don't overfill! |
I noticed the smell of coolant when standing outside the truck after running. Same thing with my brother's 6.0. Fan turned off and on constantly with mine.
Niether of our trucks showed unusual engine temps, even when there wasn't a drop of coolant left. |
The way I always find out is I hook up my trailer loaded ( 14K lbs ) and tow up a hill. Watch the coolant temp gauge, if it starts rising quickly,,, see your mechanic!
