06 Trans Fluid/Filters Change Question - Page 3 - Ford Powerstroke Diesel Forum
post #21 of 24 Old 02-27-2010, 06:01 PM
Slacker
Evil Eye's Avatar
Quoted: 223 Post(s)
Feedback Score: 4 reviews
There is now a technician bulletin that actually authorizes the use of LV in lieu of and to supplement SP in the 5R110 transmission.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #22 of 24 Old 02-27-2010, 06:06 PM
amdriven2liv's Avatar
Quoted: 4 Post(s)
Read all the way, you will come across this:
http://www.fcsdchemicalsandlubricant...ickref/atf.pdf
Then this:
This was released on 11/26/09 and is the most up to date info...
MESSAGE TITLE: REPLACEMENT TRANSMISSION FLUID FOR SERVICING TORQSHIFT TRANSMISSIONS
APPLICABLE VEHICLES :
2003 - 2005 TRUCK : 00126 EXCURSION
2003 - 2008 TRUCK : 00028 F-SERIES
2004 - 2008 TRUCK : 00016 E-SERIES
2006 - 2008 TRUCK : 00175 F-SERIES MOTORHOME
2006 - 2008 HEAVY TRUCK : 00168 LOW CAB FORWARD
OASIS MESSAGE :
ALL 2003-2008 F-SUPER DUTY, 2003-2005 EXCURSION, 2004-2008 E-SERIES AND
2006-2008 LCF VEHICLES EQUIPPED WITH A TORQSHIFT AUTOMATIC TRANSMISSIONS SHOULD
BE SERVICED WITH MERCON LV AUTOMATIC TRANSMISSION FLUID IN PLACE OF MERCON SP.
THIS INCLUDES TOP OFF AS WELL AS FLUID REPLACEMENT. MIXING MERCON LV AND MERCON
SP IN THE TORQSHIFT TRANSMISSION IS ACCEPTABLE. USE MERCON LV TRANSMISSION FLUID
TO SERVICE VEHICLES EQUIPPED WITH TORQSHIFT TRANSMISSIONS. WHEN ADDING OR
REPLACING TRANSMISSION FLUID IN A VEHICLE EQUIPPED WITH A TORQSHIFT
TRANSMISSION, USE MERCON LV TRANSMISSION FLUID.
APPLICABLE SYMPTOM CODES :
500000 DRIVELINE
504000 DRIVELINE OTHER AUTO TRANS CONCERNS
510000 DRIVELINE FLUID CONCERNS
Reference: SSM 21114
2004 F350 6.0L CC LB 4x4 King Ranch
amdriven2liv is offline
post #23 of 24 Old 02-27-2010, 06:08 PM
Quoted: 4 Post(s)
Also from:
http://www.fordtechservice.dealercon...09Hotsheet.pdf
MERCONŽ LV Service for 5R110W Automatic Transmissions Approved
Beginning immediately ALL previous 5R110W automatic transmissions (2003 to 2008 MY) can be serviced with MERCONŽ LV
automatic transmission fluid in place of MERCONŽ SP. This will result in significant complexity reduction for customers using 5R110W
automatic transmissions which can now all be serviced with MERCONŽ LV ATF (previously only 2009 /10 MY 5R110W automatic
transmissions were serviced with MERCONŽ LV). This pertains to topoff as well as fluid replacement. Mixing of MERCONŽ LV and
MERCONŽ SP in the 5R110W transmission is acceptable.
Extensive testing has been performed to ensure there are no functional or durability concerns with the use of MERCONŽ LV ATF in the
5R110W automatic transmission.
Vehicles affected are F-Series Super Duty trucks (including chassis cab) (2003-08), Excursion (2003-05), F-53 Motorhome (2006-08),
Low Cab Forward (2006-08) and E-Series (2004-08) with 5R110W automatic transmissions.
Note: Vehicles equipped with the 6R (2008 and prior) and 6HP26 automatic transmissions still must be serviced with MERCONŽ SP.
This includes V8 Explorer/Mountaineer (2006-08), Expedition (2006-08) and Navigator (2005-08).
Motorcraft MERCONŽ LV is now available in three sizes:
Part Number XT-10-QLVC -- 1 quart
Part Number XT-10-DLV -- 55 gallon drum
Part Number XT-10-BLV -- Bulk
Further information can be found in the on-line Automatic Transmission Fluid Chart or SSM #21114, accessible from the PTS Home
Page. .
post #24 of 24 Old 02-27-2010, 06:28 PM
jwindbigler's Avatar
Send a message via Yahoo to jwindbigler
This is what I wanted to hear:
Quick and easy, straight from oasis. Thanks for the input guys
Please sign this petition to have the commercial vehicle fees removed from your yearly registration (CA residents only)
jwindbigler is offline
