Replace oil cooler or ok for 3k plus road trip???????? - Ford Powerstroke Diesel Forum
Old 02-10-2010, 03:48 PM
Send a message via AIM to wildfingas
I am suspect of a bad oil cooler on my early 03 6.0L. I am getting normal temps around town but as soon as I get on the highway I am seeing a 20-30* difference in ECT-EOT. I get about 178-180 on my ECT and anywhere from 190-210 on my EOT. The later of the 2 being the highway driving unloaded. When towing it see 210+ up to 220. The temps here are 20-30f.
I am not seeing any oil in the coolant or vise versa. I am waiting my UOA to come back from black stone but for the past 3 test I have not had any coolant present in my oil. I assume that these temps have been this way for some time but only was able to see it when I installed my insight.
I would like some feed back from some techs on what I should do. I am going on a road trip on 2-19 and would like to get this straightened out before then. I have two issues. A possible ICP w/o codes and this oil cooler issue.
If I need to replace the cooler I would like to know if anyone has any pdf files of the shop manual on removing whatever needs to come out for the oil cooler. I had the egr delete done but tech never mentioned oil cooler plus I didnt even think of it at the time so shame on me.
If anyone has some advice and shop manual print outs it is greatly appreciated
Old 02-10-2010, 05:46 PM
Feedback Score: -1 reviews
its a straight forward repair. turbo and intake must come off. once out of the way I think its nine 10 mm bolts removed from the oil cooler housing and it will lift off. the repair kit you buy from ford has instructions with photos included from international. give her hell and get it done before you go on your trip.
Old 02-10-2010, 05:49 PM
and get a coolant filter kit.
Old 02-10-2010, 06:48 PM
Powerstroke Techie
And don't forget to replace the screen under the oil cooler too.
Old 02-10-2010, 07:19 PM
if u have a high pressure pump pressure leak , it would heat up Ur oil also. but normally u will get a slow or no start after a hard run an try to restart. my 03 f550 also my fan blew alot more often and louder
Old 02-11-2010, 03:57 AM
Spanks guys for the help! Definitely appreciated.
