Welded EGR valve??? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 02-10-2010, 07:51 AM Thread Starter
RIP Cam!
Rattlesnake18's Avatar
Quoted: 1119 Post(s)
Feedback Score: 6 reviews
Welded EGR valve???
Quick question... If I weld my egr valve closed, will it cause any damage if I run it for a while without completely blocking the cooler or removing it? I am going to do the egr cooler delete soon, but $$$$ is real tight right now.
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
post #2 of 8 Old 02-10-2010, 07:56 AM
LHMissions's Avatar
Just unplug the sensor. May throw a code on the '04's - some did - some didnt. That in itself will tell you what to expect as a basis. Consider the DIY full EGR delete here on the forum found under the Mod Help section. I had this done to my '03 for about $50 total. Awesome results! Cheap too!
'03 6.0 F250 FX4 Supercab Longbed 4wd <>< - SOLD
225,518miles!
Diamond-Eye 4" Off-road turbo-back
Full DIY ERG delete, Zoodad Mod, 5R110
ARP studs!!! and Decked Heads, Autometer EGR & Glowshift EOT, ECT, Boost
18x9 Black DC-2 and LT295/70R18E Nitto Terra Grapplers
LHMissions is offline
post #3 of 8 Old 02-10-2010, 08:01 AM Thread Starter
RIP Cam!
What happens if you don't unplug the sensor and weld it? My other issue with deleting the cooler as opposed to blocking it is that I have to have emission tests done every other year or so. not sure if the cooler is something they look for or would even know if it was gone. I saw the write up on it and am seriously considering to doing it if I knew it wouldn't bite me in the arse later.
Thanks for your input!!!!
post #4 of 8 Old 02-10-2010, 08:14 AM Thread Starter
RIP Cam!
post #5 of 8 Old 02-10-2010, 09:24 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
The EGR cooler still remains a problem potential even if it is blocked off. It continues to flow coolant and can still ruputer and leak. If you are subject to emissions and want to keep the EGR cooler and fix the problem for good replace it with the cooler from Bulletprrof Diesel.
Ford_Power_Stroke_EGR
Then just unplug the EGR valve. This is the cooler that Ford should have designed. Personall I favor the full delete but if you can't or don't want to....
RIP Mitch
the Org crew
PGreenSVT is offline
post #6 of 8 Old 02-10-2010, 09:34 AM Thread Starter
RIP Cam!
aside from rupturing or leaking, will it do any damage to the motor? Is it really necessary to unplug the valve if it is welded shut?
Thanks for you input!!
post #7 of 8 Old 02-10-2010, 12:40 PM
w_huisman's Avatar
If you have the early version of the EGR cooler, the odds of it failing are pretty slim. The early version is round tube-shaped, the newer version used in 04.5 - 07 is square.
So IMO, if you have the early version you could just as well leave it be till you're also ready to plug the exhaust influent or totally delete it.
06 F250 Lariat cc sb FX4
97kmiles, coolant filter
analog FP gauge + Edge Insight w/ EGT
strategy VXCF9H7
As of 1/5/12, one of MANY SATISFIED CUSTOMERS of Ed at
w_huisman is offline
post #8 of 8 Old 02-10-2010, 01:23 PM
Ihre Mama mag mich
Ozone-etr1's Avatar
YOU MUST UN PLUG IT WHEN WELDED SHUT!
it will still try to cycle and over heat,i welded mine but i have the tunes to have it inoperable
Now this was a superior machine. Ten grand worth of gimmicks and high-priced special effects. The rear windows lit up with a touch like frogs in a dynamite pond. The dashboard was full of esoteric lights and dials and meters that I would never understand.
Ozone-etr1 is offline
