School me on vacuum pumps - Ford Powerstroke Diesel Forum
Old 02-07-2010, 12:22 PM
Okay, first a bit of history. 2006 F350 DRW. Last fall/winter I had a squirrel problem...they made a nest on top of the passenger side battery. Little bastards managed to chew thru the ac wiring, both vacuum lines that run to the pump and a few other wires. I found it, cleaned everything out and repaired all. Things were fine until a few months ago when I discovered the 4x4 wouldn't shift on the fly. Turned out they got in there again and got the vacuum line AGAIN! I got it fixed and all was good. Well yet another came back and got to the vacuum lines again (same ones). I repaired and all was good
Now, here's the issue. I went to work the other day and everything was good. Jumped back in the truck and the climate control defaulted to defrost and would not change. While I was looking for another vacuum leak I discovered that the vacuum pump would not shut off. A few days go by and now everything works fine as I have both 4x4 and full climate control. But the pump will run for 2 minutes, cycle off and pulse, then run continuously again, all while everything is working fine. I assumed that they were only supposed to run to build vacuum into the canister and then shut off, only to cycle on /off as needed. What is the proper procedure for these things?? Help as I am at my wits end with this issue.
PS....still working with trying to get rid of the squirrels!!!
Old 02-07-2010, 02:23 PM
You assume correctly on the operation. Three common places for vacuum leaks - 4WD hubs, heater flow control valve (heater hose by the firewall), blend door (behind the glovebox).
Old 02-07-2010, 04:33 PM
Feedback Score: -1 reviews
yeah the control valve for the heater is super common. they fall off if the wind blows to hard to the east on a cold day in april.. lol j/k they dont fit worth a damn, if you find it off, replace the end with a unit from ford. fits better and shouldnt be an issue again.
Old 02-07-2010, 04:36 PM
Great to know. Thanks for the info!
Old 02-07-2010, 05:07 PM
Sounds like you might want to look into some kind of braided hose wlhere those boogers like to nest up!
Wonder if something like STAINLESS STEEL BRAIDED would work?
Old 02-07-2010, 06:24 PM
Thanks guys, I'll check the heater control valve. But why would it be working now? It went from working to not working back to working. Any ideas? I wouldn't think a vacuum leak would be intermitent.
Old 02-07-2010, 07:16 PM
I would be having squirrel stew to solve the problem
