Used 2005 6.0L
Hey guys. I posted this on the .com site as well but wanted some opinions from this board, too. If you frequent both, I'm sorry for the double post.
I have a chance to pick up an 07 Super Duty with 58000 miles from a local bank. They are asking rock bottom wholesale which is $23000. The guy who had the truck put a lift kit and 20" Mickey Thompson wheels on the truck and other than being really dirty, it is a nice looking truck. I have a concern about the power steering. I looked up the VIN with a local dealer and it indicated the drag in links were replaced in 12/08. The power steering seems non existent while sitting still or at idle rpms. It has a Pro Comp lift kit with steering stabilizers and he has 325/60-20 tires on it. Is it common for the steering to be that hard for tires that big considering the stabilizers? The power steering works great once you get the speed up. The truck also had to have the ECM replaced and Ford wouldn't do it because it had a performance tune. The bank had a reputable local diesel mechanic replace it. He said Ford had voided the warranty. The Oasis mentions nothing about the warranty being voided and only shows the "drag in links" back in 2008 being replaced. No open items or recalls. I think the dealer just refused to repair it and Ford can't just void a warranty cart blanch. The truck will need about $3000 worth of repairs. Tires (they are literally slick.) Repair a scrape on right rear Replace both mirrors Replace trailer connector Detail the truck Alignment It appears that a real no caring dumb___ owned the truck. I drove the truck and other than the steering issue it seems to run good. I've owned an 05 6.0 and currently have an 08 6.4L. I value the opinions on this board so I'd appreciate any comments ans to whether you would consider this truck. I will probably flip the truck locally. ![]() Thanks. Chris |
How does it look under the hood?
Is there white stuff all over the overflow tank? Thats a really good deal for an 07. |
I have an '06 with the 6.0.... not to impressed , i have the diablo sport, the s&b cold air intake and 4" staight pipe exhuast w/out cat or muffler .....still best fuel mileage i can get is 12, and its much worse pulling my bobcat...any advice?
i change the fuel filters every 10000 miles and oil/ oil filter 5000 miles, air filter is new. all the changes i have made were to gain mpgs and so far they have not improved I dont have a heavy foot. |
You should start your own thread so you dont clutter up the op's thread.
I am new to this, and i am not sure how to start a new thread.... sorry not tryn to screw things up
Hmmm... voided warranty, dumb previous owner sticking a tuner on it, prolly didn't do head studs, or even gauges, who knows how high exhaust temps have been...
Sounds like it might be trouble. Pity, a sharp looking truck. |
The warranty is not voided. But, you are right in the fact you never know how it was treated. No visible oil or coolant leaks. Has not been to the dealer for any warranty work except for the drag ins so it appears to be a sound truck other than the cosmetic stuff.
![]() Can you get them down to $20,000 due to the expected $3,000 in repairs? |
