FICM Repair
After reading about this yesterday I am seriously contemplating doing it. I was hoping it would help with my cold start ad long crank time issues. I am really worried that I might do irreversibe damage to it though. Has anybody else done this and how hard would it be to really screw it up?
Detailed FICM Repair Procedure |
Yeah I guess checking the voltage would be a good place to start before I tear it apart.
I did it and it cured my problems. If you are careful you won't screw the FICM up. |
Do you turn the key to the on position, or do you crank the engine over?
also wondering
DRQUAD FICM TEST and REPAIR
Go to this thread. Drquad's write up is in a pdf down the thread. Do not start motor with his test.
Detailed FICM Repair Procedure Also, look in tech files for more info. Last edited by amdriven2liv; 02-06-2010 at 07:01 AM. Reason: Check tech files |
you need to crank the engine to get proper results. check it key on engine off, key on engine cranking and it also needs to be checked when engine is at full load (wide open throttle) as well. let us know what voltage you come up with. anything below 45 volts and it needs to be done.
Nice, thanks for the replies.
