Fuel Injectors - Ford Powerstroke Diesel Forum
post #1 of 11 Old 02-04-2010, 04:51 PM Thread Starter
Fuel Injectors
What are the CC's for stock injectors on the 6.0? I thought about gettin' bigger injectors and I was wonderin' if I maybe needed to get a bigger/better fuel pump and/or fuel lines than my stock ones. (Have stock fuel pump and lines.)
Brody133 is offline
post #2 of 11 Old 02-04-2010, 04:55 PM
1978psd's Avatar
140cc for SD 7.3 stock injectors and 90cc for the obs single shot injectors
1996 F-250 7.3 Powerstroke 4x4
tymar intake, CPR mod, CCV mod, tripple pilar pod with boost, trans temp and EGT, 4" MBRP turbo back exhaust with 5" tip
AND
1978 F-250 4x4 ranger
400 engine, 4-barrel carb, aluminum intake, chrome kit, C6 trans, race track molding
1978psd is offline
post #3 of 11 Old 02-04-2010, 07:48 PM
Stoker0560's Avatar
Upgraded fuel system is a must! The stock fuel system can barely keep up with the stock sticks, let alone bigger ones. i believe stock stick are 120cc but they actually only put out about 100cc.. dont quote me on that but i believe thats what i was told..I would look into an AirDog2 DF130.. thats what im most likely going to get for mine, its a stand alone adjustable pump. it alone will make your stock injectors very happy! Maybe do a crossover at the back of the heads with the AD2 also, to balance pressure at the heads..also you will want a fuel pressure gauge so you can accurately adjust the pressure at the pump.
there are also other pumps and set-ups out there, just have to find the best set-up for your needs, everyone has a different opinion on fuel systems,
but like i said, fuel system FIRST, bigger injectors SECOND!
09 F450 CC LB lariat 6.4 black on black 23k miles, stock.. (For now)...
97 F250 SC LB 4x4 7.3 05 Superduty axels, 18" King Ranch Rims, "under the knife"
Former 6.0 Owner. (05,05,03)
Stoker0560 is offline
post #4 of 11 Old 02-06-2010, 12:13 PM Thread Starter
Ok, thanks! That's just the help I needed. Well, I guess I'll have to wait a little bit for all that... need to save up a little.
Brody133 is offline
post #5 of 11 Old 02-06-2010, 12:24 PM
If you had read his post instead of just vomiting useless information you would see he is asking about 6.0L injectors.
2012 F-150 XLT Ecoboost SuperCrew 6.5' 4x4
cartmanea is offline
post #6 of 11 Old 02-06-2010, 07:18 PM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
Actually the 6.0 injectors are about 135cc. It depends on what size injectors you want to install whether you HAVE to upgrade the fuel system but there are other good reasons to do so.
RIP Mitch
the Org crew
PGreenSVT is offline
post #7 of 11 Old 02-06-2010, 07:22 PM
scuffs *****
Tyler's Avatar
Send a message via AIM to Tyler
6.0 Injectors are 120CC, but the computer will ONLY allow 100CC of fuel to flow.... if your wanting to go bigger, you can go to 155's with no issue.
Sr. Engineering Tech/OPS Technician @ Your local cable company.
1997 7.3L PSD
| 4" MBRP Exhaust | S&B CAI | Torque Converter Lock-Up Switch | Exhaust Brake | FPR Shim |DB High Torque Starter | 188,000 Miles | Xtreme Daily Tune |
SOLD
2014 Ford Fusion SE
| 1.6 EcoBoost | 6-Speed Manual | The basics and some goodies |
Tyler is offline
post #8 of 11 Old 02-06-2010, 07:26 PM
Ihre Mama mag mich
Ozone-etr1's Avatar
that being said are the 155cc injectors considered to be thoes claim to fame 90 hse upgrades?
Now this was a superior machine. Ten grand worth of gimmicks and high-priced special effects. The rear windows lit up with a touch like frogs in a dynamite pond. The dashboard was full of esoteric lights and dials and meters that I would never understand.
Ozone-etr1 is offline
post #9 of 11 Old 02-06-2010, 07:28 PM
scuffs *****
Tyler's Avatar
It all depends on your tuner..... a studded 6.0 with a good xtreme race tune can put 420 to the wheels, and 155's with a good tune can put out about 500 to the wheels.
1997 7.3L PSD
SOLD
2014 Ford Fusion SE
Tyler is offline
post #10 of 11 Old 02-06-2010, 07:35 PM
Ihre Mama mag mich
Ozone-etr1's Avatar
sct/ mat&eric no studs yetbut i need to get some injectors mines failn fast
