RPM at 70 MPH? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 02-03-2010, 09:02 PM Thread Starter
Pitcher's Avatar
RPM at 70 MPH?
I bought the truck used and I am trying to figure out if it still has the stock gearing.
Would like a little bit better mileage is possible, but anyways I was curious about what RPM you Guys and Gal's are running at 70.
I run at just under 1750 RPM at 70. And get an average of just under 13 MPG but it is mostly city, However oddly enough I don't get much better on the freeway.
Anyhow any input would be great.
Thanks!
2006 F350 Tow Boss 4x4
Pitcher is offline
post #2 of 12 Old 02-03-2010, 09:07 PM
scotty2280's Avatar
i cant remember off hand what 70 is, i know on mine 80 is around 2250.
studs,egr delete(sinister),dieselsite coolant filter, nuc oil bypass, dj's fuel + regulated fuel return, sct by eric, 4in silverline no cat, isspro gauges, cat elc coolant, hids, lots of other odds and ends......
scotty2280 is offline
post #3 of 12 Old 02-04-2010, 02:06 AM
artsamm's Avatar
What is your RPM at 60, and what is the diameter of your tires?
Math at 60 MPH is easier
artsamm is offline
post #4 of 12 Old 02-04-2010, 02:10 AM
artsamm's Avatar
Here is a posting response from a while back with someones elses question about gearing
If I know your tire diamter and RPM at 60, I can probably figure for you.
To calculate at 60MPH:
Multiply tire diameter by 3.14159 (PI) You: 38 inch tiresX3.14159=119.38 inches (tire circumferance)
Divide Tire Circ by 12 (circumferance in feet of tire) Yours is 9.94
5280 (feet per mile) 5280 divided by 9.94 or 5280/9.94= 531.18 tire revs per mile
531.18X 4.30(your axle ratio)= 2282
2282 x trans ratio= engine rpm's at 60MPH
2282X.712(O.D.)= 1624 engine RPM's
2282x 1.0 = 2282 RPM's in direct drive (gear before over drive)
So...1624 RPM's at 60MPH in overdrive
I'm not calculating RPM's at 65MPH because I've had a few beers and I might hurt my brain!
Will work on though!
Site with Ford trans ratios
Ford Motor Company Transmission Gear Ratio's
Hope this helps
artsamm is offline
post #5 of 12 Old 02-04-2010, 05:31 AM
Mine is doing 2000 @ 75 with 3.73s. Sounds like yours a little different because of the tires.
2013 F250 CC/SWB Lariat FX4
325/60/20 Nitto Terra Grapplers
NOBAMA!!
Is it just me, or does it seem like all Dodge drivers are A$$holes?
jdalhaus is offline
post #6 of 12 Old 02-04-2010, 05:35 AM
bevansracing's Avatar
Mine at 70 is between 2300 and 2400.......but I have 4.10 gears so thats to be expected.
Lonestar Powerstrokes Texas Chapter Member, 08 King Ranch FX4 79k miles .......................
2001 F350 Dually 7.3,4r100,4.10 gears, 214,000miles,Lariat pkg,zoodad mod,Autometer gauges,4"straightpipe w/6"tip, HID 6000K headlights and fogs, Line of Fire ,custom painted flames and pinstripes by owner,4pos chip from DIESEL INNOVATIONS ( thanks David )"SOLD", 2005 Eddie Baur Ex. with Rousch exhaust and cold air kit, 99 Corvette w/LS1
bevansracing is offline
post #7 of 12 Old 02-04-2010, 06:05 AM
topdwg's Avatar
At 70 with 3:73's on a 37 inch tire your rpm's should be around 1500. With 4:10's, 1824, and 4:30's, 1913. Hope that help's...
2012 F-350 SRW King Ranch
SOLD - 2004 Lariat F-250 4x4
6.5 Pro Comp Lift W/ Fox Shocks, DeeZee Tool Box, 08 Diff. Cover, 37x13.5/20's Pro Comps, Zoodad Mod, SCT w/custom tunes, 4 in EX., AFE Intake, ARP, Recon Lights, High Idle Mod, RCD EGR Delete, Fumoto Valve, Oil Bypass Kit, 03 Turbo, Yukon Gears, Farmboy Stage II Traction Bars, Dieselsite Coolant Kit, Amsoil, HIDS, Edge Insight CS, PHP FICM
topdwg is offline
post #8 of 12 Old 02-05-2010, 01:17 PM
My Dream's Avatar
I am all stock, @ 70 mph with 3:73 gears I am dead on 2,000 rpm.
James
My Dream is offline
post #9 of 12 Old 02-05-2010, 01:21 PM
coolfry73's Avatar
Send a message via Yahoo to coolfry73
I am really close to 2,000 rpm @70mph
Chad
2007 F350 C/C SWB 4x4 KR
coolfry73 is offline
post #10 of 12 Old 02-05-2010, 02:05 PM
scotty2280's Avatar
yep that sounds right.
