How often should the A/C comp. cycle? - Ford Powerstroke Diesel Forum
Old 02-02-2010, 06:51 PM
Just a quick quesiton for your guy's. My A/C compressor cycles every 15 seconds or so at idle. I'm aware this could be because it is a little undercharged. It blows cold and blows cold fast when you turn it on. I'm wandering if it's normal. I know it's supposed to cycle due to having a orifice tube instead of an expansion valve. But is mine cycling too much? There are TONS of SD's in my town and it seems like I remember the ones I pay attention to cycling alot too.
Old 02-03-2010, 02:15 PM
yes, it will cycle alot whith use of defrost.
Old 02-03-2010, 05:15 PM
I have noticed what sounds like the clutch engaging on mine with just the heat on, that didn't seem right to me. Does anybody know if the compressor should cycle on just heat?
Old 02-05-2010, 09:09 PM
mine does, wondered about that tonight. I even turned the controls off and it still cycled a lot???
Old 02-08-2010, 06:01 AM
How can you tell the A/C is cycling?
Old 02-13-2010, 07:29 AM
