Gears ??? - Ford Powerstroke Diesel Forum
Old 02-02-2010, 06:30 PM
Send a message via Yahoo to Brooks19
Gears ???
i have a 6in pro-comp lift and i run 37's im thinking of re gearing my truck! iv been told to do 4:88's what do you guys think. will this help my MPG's go back up! thanks i got a guy for 900$ is that good?
Old 02-02-2010, 06:34 PM
Feedback Score: 3 reviews
I just talked to a off road shop and they said they would put 4.10 in front and rear and put new bearings while they were in it for around 800 so ur price isn't to bad I don't think
Old 02-02-2010, 06:38 PM
Lbs Lbs is offline
Those prices are great, I got quoted $1700 for front and rear. That's installed with a complete rebuild kit for both front and rear axles.
Old 02-02-2010, 06:39 PM
IMHO 4.88's would be absolutely rediculous. Especially if you ever touch the interstate. I'm planning on doing 4.30's. Puts you back real close to the stock gear/tire ratio.
Old 02-02-2010, 06:44 PM
Lbs Lbs is offline
Agreed, I had 4.88's in my Z71. I cant imagine putting them in my powerstroke, way too low of a gear for the power we have in these trucks.
a shop wanted 1800 to do it so i started to look else where, and found a guy on the side for 970 or so! but not too sure what gears need to go in
Old 02-02-2010, 06:47 PM
So what's everybody got now 3.73 or 4.10
Old 02-02-2010, 06:48 PM
stocks r 3:73
Old 02-02-2010, 06:49 PM
Lbs Lbs is offline
Get 4.56's. Even though 4.30's will bring you close to stock, if you're gonna spend that much money you might as well go a little lower and get a little more power. Don't plan on running any tire smaller than your 37's though, if you do then go with 4.30's or even 4.10's.
Old 02-02-2010, 06:51 PM
now doing this will help with my MPG right?
