What diff lube should I use? - Ford Powerstroke Diesel Forum
Old 02-01-2010, 07:34 PM
Going to change my diff fluid Should I use Amsoil or Royal Purple 75w140?
Old 02-02-2010, 05:46 AM
I'd stick with OEM. It's full synthetic too...
Old 02-02-2010, 06:48 AM
I use amsoil, look at my sig
Old 02-02-2010, 07:06 AM
i used ams oil, i dont think it really matters as long as its at least oem.
Old 02-02-2010, 08:23 AM
I would use Amsoil before the RP any day.
Old 02-02-2010, 08:30 AM
Im using royal purple and will keep using it.
Old 02-02-2010, 08:31 AM
Amsoil Severe Gear is very good stuff. I used RP when I changed gears, but next fluid change will be to Amsoil.
Old 02-02-2010, 09:15 AM
I have seen some test results that really don't favor the RP. I put RP in my Mustang recently when I rebuilt the posi and swapped to 4.10 gears but I am going to drain it and switch it over to Amsoil.
Old 02-02-2010, 09:30 AM
Probably the same test I saw that showed Amsoil Severe Gear winning every test by a large margin. The test was performed by Amsoil though, so who knows. It does seem like a good product though. The RP didn't do as well because its viscosity is lower (hence their MPG claims) and it didn't protect against corrosion very well.
Old 02-02-2010, 04:21 PM
Another thing is that ams is cheaper than royal purple. Especially with their preferred customer program. Even with the first purchase it is still cheaper than RP
