CCV Mod for 6.0L - Ford Powerstroke Diesel Forum
Old 02-01-2010, 06:18 AM
Question CCV Mod for 6.0L
So I've been reading about installing a CCV Mod with filter/strainer on my 2004 F250 S'Duty. No problem with mount location, spec'ing out the parts, or making a custom mount. What I need to know is where is the hose or hose connection located that I need to reroute through the strainer then back into the intercooler intake system. Any photos or tech drawings would be extra helpful. Thanks to all ya'll for your input.
Old 02-01-2010, 06:26 AM
Its below the air intake at the tubo on the valve cover (Driver side)
Old 02-01-2010, 05:17 PM
Smile
Thanks a lot, 03-blue-Powerstroke. Looks like once I remove the S&B Intake the CCV connections will be pretty accessible. Planning to mount the filter/strainer in the right rear corner of the compartment, just to the right and slightly behind the coolant degas tank. Looks like there should be room and the hose runs will be nice and short.
Can you tell me... is the hose I.D. at the CCV connection on the valve cover 3/4"? And is it the same at the connection to the intercooler intake? I've read several threads that suggest installing a 1" strainer unit to reduce the air flow pressure drop so I guess I'd just step up the hose I.D.s to mate up.
Thanks again for your quick response.
Old 02-02-2010, 08:21 AM
Im not sure on the hose size, it might be 5/8 but heres a for you...
Old 02-02-2010, 08:29 AM
I'm sorry and please pardon my ignorance (I'm fairly new to this forum stuff)... but what does it mean that you have a "bump" for me?
Old 02-02-2010, 08:31 AM
It puts your thread at the top of the active topics list so more people will see it.
Old 02-02-2010, 08:33 AM
Thumbs up
Excellent! Thanks for the "bump", and thanks for the explanation.
Old 02-02-2010, 09:47 AM
I think there is a pretty good write up on how to do a DIY CCV reroute maybe someone can post a link for you.
Old 02-05-2010, 03:41 PM
BigRing66, which strainer are you using? Is it DIY or is there a part aI can look for?
Thanks.
Old 02-05-2010, 04:45 PM
The fitting on the valve cover is 1 inch, at least it is on the 03 I just did mine yesterday. I just split the metal crimp on each side and pull the origional hose off and slid a piece of 1 inch hose onto it. hope this helps.
