Engine Oil Temperature ? - Ford Powerstroke Diesel Forum
post #1 of 19 Old 01-29-2010, 04:34 PM Thread Starter
I have a 06 that has a 4 inch exhaust and I am now running stock tune. I have a edge insight and today while I was driving down the road I happened to switch screens and looked at my engine oil temp. It was reading 205. When I switched screens my coolant temp was reading 180. Does this sound like I am having trouble with my oil cooler? This was traveling down the interstate at around 70 with just the truck.
2006 F250 Lariat CC 4x4
4 inch MBRP Exhaust
Innovative Tuned SCT
Street Race Lite by Gearhead Automotive
Banjo Bolt Mod.
smokeless is offline
post #2 of 19 Old 01-29-2010, 04:47 PM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 105 Post(s)
Feedback Score: 3 reviews
How cold was the outside air?
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #3 of 19 Old 01-29-2010, 06:30 PM Thread Starter
right around 20 degrees out.
4 inch MBRP Exhaust
Banjo Bolt Mod.
post #4 of 19 Old 01-29-2010, 07:34 PM
Abrannan19's Avatar
Feedback Score: 5 reviews
could be an oil cooler issue, I suggests adjusting your insight to the quad display and having the coolant temp right beside the oil temp, keep an the two temps over the next couple day at operating temps and see what it does, if its consistently that much higher, you have some issues. This is why its such a good idea to have a water and oil temp gauge.
Adam Brannan
First Coast Diesel Performance
Abrannan19 is offline
post #5 of 19 Old 01-29-2010, 08:35 PM Thread Starter
Ok, how would someone even know there was a issue with there truck if they didn't have gauges? I don't notice my truck running bad or anything. When the temperatures are like this does it throw a code in the truck? And my last question is when does ford decide that their is a problem and change the oil cooler? I am just wondering if I take the truck in and say it runs fine but I think my oil temp is to high what response will I get?
4 inch MBRP Exhaust
Banjo Bolt Mod.
post #6 of 19 Old 01-29-2010, 08:41 PM
Goose350's Avatar
You wouldnt know until it failed. If you have the most recent flash on your pcm then it would throw a code for the temp differences. If it goes over a 15* difference is when Ford will replace.
The Mullet Mod
Stock 2005 F-350 4x4
*Afe Intake
*4" TB Exhaust
*Scangauge
*SCT
oil bypass
water pump
*Tuned FICM
Goose350 is offline
post #7 of 19 Old 01-29-2010, 08:53 PM Thread Starter
So when the oil cooler starts to fail what happens? Sorry about all the questions but I am not sure about how all this ties together. Oh and my truck has VXCF1 strategy in it.
4 inch MBRP Exhaust
Banjo Bolt Mod.
post #8 of 19 Old 01-29-2010, 09:26 PM
Abrannan19's Avatar
yes, ford will datalog the truck and see the temp difference, they will then replace the EGR and Oil cooler most likely when they see that temp difference. When the oil cooler starts to fail it can be because of a failing EGR cooler not allowing enough flow of coolant out of the oil cooler or the oil cooler could be internally restricted reducing coolant flow, if its left like this, you can have a mess, with oil mixing with coolant. Keep an eye on it over the weekend, if you continue to see the temp diff. and are still under warranty, take it to the dealer on Monday and tell them you are seeing a 15* difference between oil and coolant temps, the tech will datalog it and see the same data you are seeing with your insight.
Adam Brannan
post #9 of 19 Old 01-30-2010, 07:21 AM Thread Starter
ok, thank you.
4 inch MBRP Exhaust
Banjo Bolt Mod.
post #10 of 19 Old 03-20-2010, 06:45 PM
scottinal's Avatar
Wow, I just got an Insight installed and I am finding my oil temp is 30 degrees hotter than the coolant. I towed (maybe 6000lbs on mostly flat land) over to the local race track today and it got to be 40 higher (230 degree oil temp) and it was only 65 outside temp today. I am freaked now. Out of warranty by about three months (that figures) so I will make some calls on Monday to see if I can find a place to delete the EGR and I guess they will need to replace the oil cooler?
scottinal is offline
