Better Freakin' Brakes! - Ford Powerstroke Diesel Forum
Old 01-29-2010, 11:33 AM
...stock '03 brakes SUCK. Or at least mine do They are vague during the best of times, but when they started to boil fluid on the way down a hill (Mt. Baldy last night), with only my daugthers in the truck (read: NO LOAD), I had about enough. Any recommendations for good replacement rotors/pads that won't break the bank? I don't care about dusting or any of that other stuff--I just want brakes that stop, and don't fade so darn easily... TIA!!!
P.S. And my parking brake... Hmmmm... I guess I should look at fixing it too...
Old 01-29-2010, 11:44 AM
Has the fluid been changed recently? From what I have read that can make a world of difference. Speaking of changing the brake fluid, I need to do that soon!
Old 01-29-2010, 11:46 AM
It looks clean, but it's probably older fluid (I bought the truck with only 41k miles on it). I would definitely do the fluid when I replace the rotors/pads--but I think the pads and/or rotors are badly glazed at this point...
Old 01-29-2010, 11:48 AM
Send a message via AIM to jhaddox
powerslot rotors with hawk pads
Brakes
raul has the rotors and i thought he had the pads too? but i couldnt find any on his site
Old 01-29-2010, 12:10 PM
Brakes
Just the kind of info I was looking for! Thanks!!
Old 01-29-2010, 12:28 PM
+1 for the Powerslots, but if your boiling fluid it probably has too much water in it and needs to be flushed.
Old 01-29-2010, 12:45 PM
def + 1 more for the powerslots... PM me if you need any more info or suggestions
-Raul
Old 01-29-2010, 01:04 PM
Yeah, I'm replacing the fluid at the same time. I was just surprised--my '99 truck's brakes, even when it was lifted sky-high with 39's, felt so much better. I know the PSD is heavier, but there's no way I would have made it down safely without stopping regularly if I had been towing...
Old 01-29-2010, 02:38 PM
Man I just changed my fluid and pads with EBC green stuff pads and man it's like a night and day difference. I was going to do rotors, but I figured I'd try some good pads first and I was right...
Old 01-29-2010, 03:15 PM
Do you think they are better because of the pads or fluid change or both?
