oil bypass kit
Alright, I just saw this oil bypass kit mentioned in the coolant filter thread. I didn't want to hijack so I'm asking here. What exactly is the oil bypass kit and why?
Thanks, Cliff |
An oil bypass kit routes a small amount of oil to a bypass filter which then circulates it back into your engine. The filter I use is an Amsoil which if I'm not mistaken filters the oil down to 2 microns. The bypass kit just aides in keeping your oil cleaner...
they are great i got one that uses a paper towel roll to filter the junk out, my oil doesnt get black anymore between fill ups, you technically can go farther on an oil change also because it filters the very fine particles. i reccomend one even if your going to continue the regular oil change intervals because it keeps it clean
Here's a quick pic of mine...
Alright, so it's exactly what it sounds like. I know absolutely NOTHING about the function of a diesel engine, but don't they have an oil filter on the block like a gas engine? If you wanted an extra filter, wouldn't it be easier to do a remote setup with two filters?
The 6.0 has a drop in oil filter. There are kits out there, like Amsoil that have a remote set-up, but my kit still utilizes the factory filter.
Hey ya'll,
Alright, more technical related questions.... I was reading another thread yesterday (that I can't seem to find for some reason) and I thought it sounded like the 6.0L has a bypass in the oiling system that bypasses the filter if there is not enough pressure. Is that correct, and can anyone expand on that? If there is a bypass, is that where these oil filter bypass kits are installed, or are they added in somewhere else? If they are added in somewhere else, that means there is still unfiltered oil running around the system, correct? I'm sure I'm not the only one wanting to know about this. As always, all help is appreciated. Thanks, Cliff
Right. I think I got that all right heh. |
Thanks dude.
Any other thoughts? |
