Is It Posible To make 6inch Fabtech lift into an 8?? - Ford Powerstroke Diesel Forum
Old 01-25-2010, 04:50 PM
im juss wondering if there is any other way to make my 6inch Fabtech lift into an 8 inch lift with out having to buy a whole new kit???? if so how ? and is it reliable/ safe???? Anyone Done it ? .... thanks alot!!!
Old 01-25-2010, 05:20 PM
Don't quote me on this because I don't know all the details of any of Fabtechs kits, but I would think you could just throw a 2" leveling spacer at the front end, and maybe a block or a helper spring at the rear. I need to do a little research on Fabtech myself.
Old 01-25-2010, 06:29 PM
yes its possible. my 07 had fabtech 6 inch & their 6 &8 inch kit both use the same track bar drop bracket,so i used a readylift leveling kit in front{dont need to replace shocks} in the back i used a taller block & a procomp addaleaf. i also dropped the steady bearing a total of 1 1/2 with a solid aluminum block. truck is level & rides decent..no vibration. im running 37/1350/18 nitto mud grapplers.
Old 01-25-2010, 08:23 PM
ok great....... any others???
Old 01-25-2010, 09:40 PM
I have looked into doing the same thing and have been told the same from fabtech. Call them but im pretty sure you can just through some 2" spacers in and your good
Old 01-25-2010, 10:07 PM
any reason why you havnt done it??
Old 01-26-2010, 03:17 AM
Send a message via AIM to DIVITA21
I just did it last weekend. I added 2.5 inch spacers on the front and 2 leafs in the rear. Easy job
Old 01-26-2010, 09:06 AM
can you post some picktures???? thanks aot
Old 01-26-2010, 09:41 AM
i would like to see photos too. id like to go up to 40 s but if they hit i wont
Old 01-26-2010, 11:01 AM
I would also like to see pictures. Before and after, tire and rim size, as much info as possible please.
