injector o-ring tutorial needed - Ford Powerstroke Diesel Forum
post #1 of 6 Old 01-25-2010, 01:51 PM Thread Starter
hardhatz's Avatar
Quoted: 3 Post(s)
Can anybody hook me up with a good tutorial for replacing my injector o-rings? With pics would be nice...
Also, is there any other spot my fuel system could be getting air overnight? I pressurized the tank & could not see any drips...
07 F-250 CC SB
lowered 3/5 DJM Dream Beams
overloads & 1 leaf removed
5000 lb bags & auto-leveling
6.0 PSD/5R110/3.73 posi
SCT3/Eric-IPD/Extreme Street tune
Snow Stage 3 alcohol injection.
Bulletproof oil cooler
hardhatz is offline
post #2 of 6 Old 01-25-2010, 02:23 PM
why do you say your system is getting air in it?
ASE Master Certified Technician
04 Powerstroke lovin it
thenubsterman is offline
post #3 of 6 Old 01-25-2010, 02:55 PM
Powerstroke Techie
m-chan68's Avatar
Quoted: 3 Post(s)
The part number for the o-ring kit from Ford is CM-5055 for each injector. Each kit includes the copper washer, the white, black and light blue coloured o-rings. Installation should be self-evident. Just be sure to lube up the new o-rings with clean engine oil prior to installation and torque the injector hold-down clamp to 26 ft.-lbs. Air in the fuel system is a non-issue on these engines, due to the fact that this engine uses high pressure engine oil to control the actual fuel pressure at the combustion chambers.
Ford Diesel/Senior/Master Tech who placed 2nd overall in Ontario on the Fix-It-Right-First-Visit score for 2010
....who works at a dealership that now employs SOME half decent looking female employees since they overhauled most of the administrative staff
....but STILL loves hot women with big boobies
....and STILL hates working on E-Series with 6.0L
m-chan68 is offline
post #4 of 6 Old 01-25-2010, 02:56 PM
scotty2280's Avatar
you just replace the old o rings with the new ones. or do you want the whole procedure of swapping injectors? if so, do a search on it. you will find many wright ups on it!
studs,egr delete(sinister),dieselsite coolant filter, nuc oil bypass, dj's fuel + regulated fuel return, sct by eric, 4in silverline no cat, isspro gauges, cat elc coolant, hids, lots of other odds and ends......
scotty2280 is offline
post #5 of 6 Old 01-25-2010, 03:40 PM Thread Starter
hardhatz's Avatar
Quoted: 3 Post(s)
the reason I think it is getting air is that it misses, bucks, and snorts on startup after several hours of being parked some after 8 hours of sitting, a lot more after 24 hours. First happened about a month ago, up in Washington. I thought it was from the -20 temp during the night, but since that day it has done it every day. It smoothes out after a minute or two.
In addition, it died yesterday on the freeway & won't start at all. Dunno if related or not, but either way I want to fix both issues.
07 F-250 CC SB
hardhatz is offline
post #6 of 6 Old 01-25-2010, 04:21 PM
Powerstroke Techie
m-chan68's Avatar
Quoted: 3 Post(s)
Sounds like the classic 6.0L injector stiction issue, which can only be diagnosed using the power balance screen to check, when it misses and runs rough. Another quick and easy test you can try yourself, is to remove the secondary fuel filter and fill up the housing. Crank the engine over with the key out of the ignition, by using the jump starter on the passenger side of the engine, and peak inside the secondary fuel filter housing for the presence of bubble(s). If bubbles appear, it means you have compression gases leaking into the fuel system.
m-chan68 is offline
