Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > General 6.0L Discussion
Old 03-21-2006, 04:46 PM
Greg Greg is offline
06 Mirrors
I am looking at buying a 06 f-250 xlt with the power heated sliding mirrors. I was wondering if you can swap to the smaller style mirror with out any problems or not? Thanks for any information
Old 03-21-2006, 04:50 PM
mschn99 mschn99 is offline
Banished
yea....i dont see why not unless there is a funky design change in the inside door skin.....just pull the door panel, unplug the electrical connector, and take out the nuts that hold it on (3 if i remember right).....thats the first time ive ever heard someone wanting to go to the smaller ones though.....
Old 03-21-2006, 06:42 PM
purduefarmboy460 purduefarmboy460 is offline
Send a message via AIM to purduefarmboy460
what are you doin with the larger ones?? I've been lookin for a set
Old 03-21-2006, 06:44 PM
Banished
electrical connectors may be different for yours adam....you may have to do some wiring to make them work.....just so you know
Old 03-24-2006, 03:44 PM
Thanks for the info, So I can get the smaller ones and still have the power adjustable mirrors. What about the heated glass part do the small ones have that to? also what do you do about the blinkers just leave them unplugged? I know it's just the opposite of what everyone does but I think they look better all I am going to do is pull a racecar . Thanks for all the help.
Old 03-24-2006, 03:47 PM
Banished
you may have to buy an electrical pigtail and wire the adjustable mirror for the truck pigtail...i didnt realize you were looking for the electrics to work too......i dont bieleave they offer the small ones with heated glass....and the turn signal wire is in the same connector....they only use one for it all.....so that may take a lake a little more work to make it function......i thought you were just asking if it would bolt in correctly.......Marc
Old 03-24-2006, 03:50 PM
Banished
i just looked at the wiring diagram....and it APPEARS that the connector in the door is the same for all mirrors.....but you will want to actually compare the old and new mirror before you try to plug the connector in......Marc
Old 03-25-2006, 05:56 AM
Thanks I was going to order a new truck but I waited about two weeks to long. I might wait on the 07's but then this one will probably be gone. The mirrors are really no big deal I was just curious if they could be changed
Old 03-25-2006, 05:57 AM
Banished
if your going to do an 07......if it was me i would buy an early model year one and get a 6.0......cause we dont know if the new 6.4 is going to be a problem child or not........Marc
Old 03-25-2006, 09:44 AM
BUKWAKR BUKWAKR is offline
06 Mirrors
I Did The Mirror Switch On My Truck There Direct Replacements Of The Towing Mirrors They'll Bolt On No Problem
Bukwakr
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
