New To Me - Ford Powerstroke Diesel Forum
post #1 of 9 Old 04-03-2007, 07:49 PM Thread Starter
New To Me
Well my adventure has begun, I just bought a 03 fx4 4 door lwb 350. It has 63k on the clock and is in mint condition. I have already read the info about 6.0's in the info forum and performed an extinsive inspection before the purchase.
So, The p.o. was an older gent that drove his cattle to the sale in it. He kept all the maintainence records in the glove box and all maintainence was performed at the dealership.
The p.o did all the leg work on the truck and traded it for a gmc.
He had the following done since new:
ICP Recall
Oil and lube every 3k documented on recipts
All Front ball joints in '06
Alignment and tires in '06
New turbo and insulation under hood
EGR recall and replace
WIF sens. replaced
VGT sens. replaced
Brake vibration repaired
6 & 15 & 30k super service
Rough idle repaired by re-programming pcm (2x)
Mass air flow sens.
Neg. ground stud recall
Tranny flush every 15k
R&L Front hub replaced
So what's left? I hope he got all the bugs worked out andything else I should look for?
03 F350 6.0 FX4 Torque Shift, Duece, LWB, 4door, Hide away Goose, Straightened up stock exhaust, Just waiting for the mods?
99 F150 5.4 4x4
wilderness is offline
post #2 of 9 Old 04-03-2007, 08:32 PM
back in the saddle
shu873's Avatar
Sounds like a well taken care of truck to me.
Kurt
'06 True Blue/Silver 250 crew cab
ARP's, EGR blocked
AFE stg.2, MBRP 4" pipe
Air Dog 150, ITP reg. return
Bulletproof oil bypass system
Banks technicooler
Ride rite air springs in the rear
EGT, boost, and fuel pressure gauges by DiProcol on the pillar
Plus a few other odds and ends...
shu873 is offline
post #3 of 9 Old 04-03-2007, 08:34 PM
Hayman's Avatar
Congrats on the new one buddy now get some pic in your garage so we all can see the beast.
Pat
2006 F350 CC
SB Beige
4"409 SS 5"Tip
2 1/2Leveing Kit
Line X Bed
Hayman is offline
post #4 of 9 Old 04-03-2007, 09:03 PM Thread Starter
Tomorrow fo show! It's quite a rig, after guages on with the bombing. I put about 130 miles on it today and all went well, no issues but I did notice some what of a chatter on the driver side when running on the road. Do the 6.0's have a typical noisy IP?
Keep in mind I have a 12v CTD that sounds like a sled puller so when I say chatter I mean just a slight chatter nothing like the Dodge. Also the upper intake boot had some oil residue on it is that from the crank vent?
Also it has a 1/8" cord hanging out of a hole under the dash cupholder w/ a switch next to it, is that for an mp3? Or does it recharge the robot that will massage my back while driving, ha ha I would'nt doubt it with all the bells and whistles this thing has on it. My folks have an 04 caddy that pales to compair to this rig.
99 F150 5.4 4x4
post #5 of 9 Old 04-04-2007, 04:47 AM
Hayman's Avatar
When you say chatter like a break caliper you mite pull the front wheel & check the shoes, for the residue on the intake i would clean it of & see if it appears back has it ever been chip? i don't know what the cord with the switch is for.
Pat
2006 F350 CC
SB Beige
4"409 SS 5"Tip
2 1/2Leveing Kit
Line X Bed
Hayman is offline
post #6 of 9 Old 04-04-2007, 06:36 AM Thread Starter
Not brake related more like valve rattle. He has all the recipts in the truck and it does'nt appear to have a chip I'll know much more after today.
99 F150 5.4 4x4
post #7 of 9 Old 04-04-2007, 09:16 AM
This happened to my 2005 f350 6.0 Diesel. From what I understand the 6.0's have had a lot of problems. This is my first problem so far, but my truck only has 34,000 on it. It died on me while i was towing. It's in the shop now. Havent heard anything yet from the service guy.
Good luck.
2005-07 F-SuperDuty/Excursion No-Start, High Pressure Oil System Leak:
Some trucks may develop an oil leak at the high pressure oil pump outlet fitting. This will cause a no-start condition as the computer needs to see at least 500 PSI before it will activate the injectors. In some cases the no-start will be intermittent and/or an intermittent stall with no codes will occur. If high pressure oil leak diagnosis indicates a leak at the pump, the pump outlet fitting (W301727) and the discharge tube block should be replaced with fitting and bracket kit 4C3Z-9B246-A. Do not torque the outlet fitting beyond 38 ft/lbs. If the leak is traced to the branch tube running through the engine block, replace with P/N 5C3Z9J332-B (requires removal of the transmission, flywheel and rear engine cover; new flywheel bolts required). TSB 06-14-6.
levalenzuela is offline
post #8 of 9 Old 04-07-2007, 04:13 PM Thread Starter
I just got back from KY today and the only issue I have had with the truck is an oil leak from around the front main seal I think. The pinion seal on the rear end is leaking too and had slid forward so I tapped it back in until my new one gets in tomorrow. All in all it seemed well. There was one point when I hit a bump on the highway and the front end seemed to engage? Almost like it was in 4x4. It has locking hubs w/ auto and lock on them. (I was'nt sure if they all had hubs)
As for drivability and comfort A+. The fuel econ was around 15.5, does that sound normal? I'll update you guys after it goes to the dealership in Mon. Thanks, Chad
99 F150 5.4 4x4
post #9 of 9 Old 04-07-2007, 05:26 PM
Hayman's Avatar
That what i get on a average 15.5 to 16 on long trips i have got as high as 19.
Pat
2006 F350 CC
SB Beige
4"409 SS 5"Tip
2 1/2Leveing Kit
Line X Bed
Hayman is offline
