2 stroke oil?
all i want to know is how much do you guys put in per tank of fuel,and is any kind of 2 stroke o.k,thanx sheldon.
Most guys run 1 oz per gallon
And make sure it's ash-less |
what brands are ashless bud.
the kind made for 2 stroke outboard motors... I think it'll say TC3W or something... In any case it will specify that it is ash-less.
![]() ![]() ![]() I think these guys and gals runnin 2 stroke are running it in 7.3 motors not 6.0 like are's . There ani't no way I'll put 2 stroke in my 6.0 no way . Are injection setups are different for the 6.0 than the 7.3 Someone will chime in here I'm sure that has a lot more knowhow. I run standalyne performance formula 8 oz. to 30 gal deisel for lubticy,cetane boost,and anti gel,it's all in one most people get a couple more miles to the gal with it also. JER-1 |
I run TCW3 every 20th tank. Diesel kleen other all the rest. I have 180K on my injectors.
Ash less= TCW3. You will see it printed on the back of the bottle. All it will do is quite up your motor a bit and lube the seals. Diesel kleen will do the same. Good luck |
I have either some withe or gray bottle power service in mine and two stroke oil. More lube cant hurt anything.
The only fuel conditioner I use in mine for the last 3 years is the wally world 2 cycle oil. Use it if the fuel is not up to par and harder on fuel. It gives the boost required to pull hard.
![]() ![]() ![]() I run 2-stroke oil in my 6.0 without problems. What's the issue???? |
