Water In Fuel
I got water in my fuel, guys! It never got in the motor or anything like that. It's just in my fuel/water separater. I was going to take that little piece off to drain the water, but you need an allen wrench to do it, and I had some. I tried a 7/32 and it seem to fit tight, but once I started putting torque on it, it slipped so I tried a 1/4 and it wouldn't even fit. Then I tried a 6mm I think it was? and it did about the same as a 7/32, so I don't know what size fits. I hope the hole isn't stripped out!
Alright, I'll go back out later and try the 6mm again.
The fuel water separator your speaking of is down by the horizontal fram mounted fuel filter right? I read my owners manual and it shows a lever that you flip down to drain the water out but when I got under my truck to look for it I didn't see anything like this. I want to familerize myself with it in case I ever have to drain this.
Correct, it's basically directly under the drivers seat along the frame rail. You'll also need to get a 6mm allen wrench. It's a good idea to drain the HFCM each time you change your oil. Don't just wait until the light comes on. |
Some '06 MY were fitted with a levered ball valve (my neighbor's '06 has one)...for the rest of us there's this guy....
Diesel Technician Society |
Well, I found my 6mm yesterday and crawled up under my truck... and lets just say I stripped the allen screw out! I don't know what to do now.
Take a hammer and chisel and break it loose and put an updated drain valve in.
