Parts motor? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 01-08-2010, 01:42 PM Thread Starter
Parts motor?
I found a motor for sale for $1000. All I know is the guy said it was in some kind fleet truck and was pulled at 90k miles. It was in an 04 and he said it ran fine and is doesn't come with a turbo or injector wiring or a few other things I'll have to find the details on. My truck is an 05 and was wondering if there is big differences between 04 and 05 motors. I was wondering if this is a good deal. I would just like to have some spare parts considering my powerstroke isn't always the most reliable. Any thoughts will be appreciated.
Ark Lariat is offline
post #2 of 4 Old 01-08-2010, 02:30 PM
Erwin8r's Avatar
I don't have a lot of specific 6.0 knowledge, but I can share some general concerns I would have: I would be wary of a "fleet truck" engine, regardless of the mileage, unless I could see it run--some of those trucks see the hardest miles (idling extensively, long maintenance intervals, etc.). The way I see it, the most expensive parts that we usually require are the injectors, the turbo, the HPOP, the Oil and EGR cooler, and the fuel pump (I might have missed a couple things like the FICM, etc.). Of those, you're already out the turbo, and who knows what condition the other parts are in. My .02? Use the money towards studs and EGR delete, and if you already have those done, then use it towards maintenance.
Edit: Another thought: If, however, you know for a fact that it ran great, it might be good as a "spare" in case yours ever takes a dump (drop one in while you redo the other).
2003 6.0 PSD Extra Cab SB 4x4
35" Toyo MT's
ARP Studs
BPD EGR Cooler
AFE Stage 2
Rhinoliner
Big-*** Fuel Tank (47 gallon?)
Erwin8r is offline
post #3 of 4 Old 01-08-2010, 02:36 PM
Send a message via Yahoo to cxrxaxz
I seen that same motor off craigs list. looked like a pretty good deal but you cant ever tell.
cxrxaxz is offline
post #4 of 4 Old 01-09-2010, 06:24 AM
Buy it and build it. Send the heads out for some work, have the block bored out a little bit maybe new pistons and rings. Have the intake horseshoe hogged out too. For a grand i see no reason not to pick it up.... i would try for less money tho
Nov 2003 built
2004 PSD F250.
SC Long Bed SRW
EGR delete, Studs, Swamps FICM, 4" turbo back
lightninmike is offline
