Batteries.. CCA? - Ford Powerstroke Diesel Forum
post #1 of 22 Old 01-07-2010, 07:20 PM Thread Starter
d4rkpri35t's Avatar
Batteries.. CCA?
I am interested in knowing what kind of batteries or atleast starting battery that you have on your trucks. I have a 440CCA battery and when it's under twenty degrees my truck will not start without the battery draining and having to put a charger and/or jump on it. While hooked up it will start with another truck or charger. What would you personally recommend on my truck.. good batteries not cheap ****.
1999 Ford F350 Dually | Tan | Stock (for now)
2006 Ford F350 Dually | Black | Sinister EGR Delete, Banks Stage 3 Turbo H/S w/ '03 C/S, MBRP 4", AFE Intake, BullyDog Programmer, 22" Diesel Wheels Atomic Series Wheels, Autometer Gauges, HIDs, etc.
1988 SSP Notch Mustang | Black | 4.6 SOHC Turbo ModFox (in progress), Tubular Suspension, 5 Lug 4-wheel disc, adj. coil overs, MUCH MUCH More!!
d4rkpri35t is offline
post #2 of 22 Old 01-07-2010, 07:23 PM
KeepinItFord's Avatar
You should have Almost double that CCA!
KeepinItFord is offline
post #3 of 22 Old 01-07-2010, 07:24 PM
Powerstroke Techie
m-chan68's Avatar
Quoted: 3 Post(s)
The original equipment batteries that these trucks come with, are 750 CCAs each. I always upsell 850 CCAs on any trucks that show up on my doorstep needing them. And I ALWAYS replace them in pairs.
Ford Diesel/Senior/Master Tech who placed 2nd overall in Ontario on the Fix-It-Right-First-Visit score for 2010
....who works at a dealership that now employs SOME half decent looking female employees since they overhauled most of the administrative staff
....but STILL loves hot women with big boobies
....and STILL hates working on E-Series with 6.0L
m-chan68 is offline
post #4 of 22 Old 01-07-2010, 07:47 PM Thread Starter
d4rkpri35t's Avatar
What about optima red top batteries?? considering i have a rather hefty stereo system in it and do a LOT of cold weather starts..
post #5 of 22 Old 01-07-2010, 09:08 PM
If you want to spend the money on them go right ahead.
the point is You have about half the CCA that the rest of the diesel world has.
Get 750cca or higher, and right away you'll notice that your truck has no problem cranking at any temp.
Most Good Batteries have warranties. so find two with a warranty or guarantee with atleast 750CCA and put them in. if your stereo system is too dope for 2 standard batteries, then get your money back and get Red Tops. or a 3rd battery, or a 2nd altenator, or dont blast ur radio when the trucks not on.
post #6 of 22 Old 01-07-2010, 09:55 PM
scuffs *****
Tyler's Avatar
Send a message via AIM to Tyler
Mine have 850 a piece, can listen to the radio with brights on while fishing for longer than I can stand to fish in the night, and it'll start right up.... I forgot to plug it in the other day, took me 5 mins to get it to start, and the cranking never slowed on them.
Sr. Engineering Tech/OPS Technician @ Your local cable company.
1997 7.3L PSD
| 4" MBRP Exhaust | S&B CAI | Torque Converter Lock-Up Switch | Exhaust Brake | FPR Shim |DB High Torque Starter | 188,000 Miles | Xtreme Daily Tune |
SOLD
2014 Ford Fusion SE
| 1.6 EcoBoost | 6-Speed Manual | The basics and some goodies |
Tyler is offline
post #7 of 22 Old 01-08-2010, 04:18 AM
MoyockPowerstroke's Avatar
Go with (2) new 850cca batteries 65N series. Also the Optimas are more because they're suited for off-road use....the way they're constructed (gelled platelets as opposed to liquid)...they are no better in terms of cca than any other leading battery brand. Nothing wrong with Motorcrafts battery, come with a decent warranty.
'05 6.0L, 128k miles, Racor CCV6000 Filter, Oil Bypass Filter, Fumoto drain valves, Coolant Filter, ZooDad, HighIdleMod, BullyDog 4" TB, VXCF9 Strat, Edge Insight Gauge, Torque App, Fuel Press Gauge, Upfitters, 4" SJ lift w/Bilstein 5100's, Ride-Rite Airbags, Rough Country Dual Stabilizers, 24" Wipers, '08 Rear Diff cover, Mobil1 Syn 5W-40, 6.4L banjos, Blue Fuel Spring, SS HPOP screen, '08 Mirrors, Zerex ELC.
MoyockPowerstroke is offline
post #8 of 22 Old 01-10-2010, 10:16 AM
07lariat's Avatar
My batteries went completely flat last month, just when the cold weather hit. The originals were 750s, replaced them with two 850s. The weathers been particularly cold lately but starting hasn't been an issue. Starts better now then it did in the fall.
07lariat is offline
post #9 of 22 Old 01-10-2010, 10:20 AM
Quoted: 5 Post(s)
850 CCA minimum in my opinion.....I use AZ duralast gold's work great, warranty is awesome, replaced no questions asked.......even though my alternator killed them and they knew that because they tested the alternator
Originally Posted by Ianstew
There is a difference in a government acting responsibly within their powers, and a government that just decides what their powers are and what responsibility means based on political whimsy.
ianstew is offline
post #10 of 22 Old 01-10-2010, 10:25 AM
jesilvas's Avatar
Quoted: 3 Post(s)
Same here. Mine went bad and I had the 3 year free replacement warranty on em. Two brand new batts and then a new alternator w/lifetime warranty.
4R100, 2wd
330,000 + miles
jesilvas is offline
