Does P0611 Code = Bad solder joints?
I have read the tutorials on resoldering the joints on a 4 pin FICM if they read less than 48 volts, but I havent found this answer, does a P0611 code relate to the same FICM failure or are they different unrelated faults?
My truck is in the shop right now with a bad #1 injector, and they say it reads a P0611 code and want to change the FICM. At $700 +programing, I would rather try resoldering before I essentially throw a big $grand$. ![]()
If that dont work i would seriously look around before throwing money at ford. You can get a new ficm off craigs list for cheap. i actually posted one on here if someone hasnt bought it. it was 250 dollars i think.
Isn't the ficm covered under the engine 100k warrenty
Covered under your emissions warranty - at ZERO deductible (up to 5 yrs and 100k miles)
truck is at 103K so no warranty. This one I am paying for myself. So I am searching for used ones also......
so warranty or not, I need to know if this code is a bigger worse problem or I can save upwards of $700+ on a new FICM. Last edited by AFBLUE; 01-08-2010 at 02:25 AM. |
Id say fix injector first, then check with test and gain, if ficm doest work shouldn't it pull coce for all injector's. m no mechanic but the last three day's working on truck, tested everything and ended up somehwere along the line water froze in my system
Swamps Diesel sells reconditioned ones - $350. Have you checked the FICM voltages? This might confirm the po611.
Please show me so I can prove them wrong and save $100. |
P0611 is the FICM death code. If you pulled that code prepare to replace it.
The FICM is not covered under the emissions warranty. Only the PCM is |
